  1. For 6 preset Traffic Pro... Try 65161
  2. Try 3684
  3. Try 8673
  4. Try 2687
  5. Try 3231
  6. Try 8931
  7. Try 1971
  8. Try 4809
  9. Try 8690
  10. There will be a delay in Lost Radio Codes this week - I will try and get to them on Friday. Sorry for any inconvience.
  11. Pretty good chance that the cruise control was not installed properly then.
  12. Right Hand Drive C4 should be "996411". It would be "996410" for LHD.
  13. Did you double check the Order Type in the DME?
  14. As I recall cruise control has to be turned on in both the instrument cluster and the DME on the MY2001 and newer models. Two places to enable it. Also, make sure the "Order Type" is properly coded in the DME.
  15. Try 8987
  16. The one illustrated in the parts list looks like just the one clamp (item 26). There is note that the clamp needs to be horizontal (as shown).
  17. Ok it might be (hard to tell from the photo) - 191 853 615 A Grommet -- US MSRP $0.78 each.
  18. Could be a bad key... or you can also try re-programming the key. Any re-programming should under the new key warranty.
  19. Sorry, no other way to program a new key other than with a Porsche PIWIS - and the proper codes from Porsche.
  20. Did you use a Porsche PIWIS to program the keys?
  21. Check the cable from the battery to the starter for corrosion - do the same for the chassis ground.
  22. Porsche does not list them as separate parts. I think a salvage yard might be a good choice.
  23. Try 8654
  24. Try 8972
  25. P1123 Oxygen Sensing Adaptation Area 1 (Cylinders 1 . 3) - Lean Threshold P1125 Oxygen Sensing Adaptation Area 1 (Cylinders 4 • 6) - Lean Threshold This is telling you your fuel mixture is too rich. So rich the DME can not compensate for it. Possible causes: - Fuel pressure too high. - Fuel injector leaking. - EVAP canister purge valve open. The most common cause we have seen here is the canister purge valve is open.
