  1. Try 0763
  2. What they call the "cap" is actually the lens housing. Do you want the color for clear (RoW) or amber (US)?
  3. Try 4985
  4. As I recall it will be either under Radio or DME.
  5. That is correct - the muffler would melt it.
  6. Only MY2002 and newer have the illuminated housing. The whole illuminated housing is: 996 652 102 10 and has a US MSRP og $11.15.
  7. Try 4734 Please consider a donation to this site - that has helped you with radio codes multiple times.
  8. Try 9680
  9. 996.2 is MY2002 and newer 996 - they use Aerokit II. A MY2001 996 is 996.1 and uses Aerokit Cup. I do not see that part or part number on either kit.
  10. 0W-40 should be fine.
  11. Try 7571
  12. Try 1307
  13. Try 0314
  14. Try 0187
  15. Try 6512
  16. Try 9698
  17. Try 6432
  18. Try 9876
  19. I am not sure if you can get to this after removing the oil pan.
  20. Try 4821
  21. I would also inspect the high current cable to the starter as they have been known to fail over time.
  22. Brake microswitch? Any codes like crank sensor? Does the transmission show in Park position?
  23. Try 8574
  24. The manual does not list separate setpoints for 3.6 liter engine. I would expect them to be the same or very very close.
