  1. Did you read my last reply - I can not help you with a CR1. These were Alpine radios and the later radios were Becker. I only have codes for Becker radios... sorry.
  2. From the Lost Radio Code FAQ "Which radios can not have their unlock code recovered through serial number? - CR1 - Alpine - CDR-23/24 (or later) - Becker - PCM (Porsche Communication Management) – Siemens & Becker"
  3. 955 522 258 00 Support US MSRP $275.87
  4. Try 5265
  5. Try 5172
  6. Try 1083
  7. Try 0710
  8. Try 2462
  9. Check your fault codes again - if it is running poorly there has to be codes. What fault code scanner?
  10. From the Lost Radio Code FAQ... "I get a WAIT on the display - what do I do? You have to wait at least 30 minutes before trying again."
  11. Try 9194
  12. Try 5039
  13. To my knowledge there only 37 factory slant-nose Turbo cars. A real one is likely close to $1,000,000.
  14. According to your voltages the alternator seems fine. Perhaps a bad ground? Start with the battery to chassis grounding.
  15. How old is the battery? A weak battery will give many electrical faults. If it is over 4 years old I would replace it. If not, then get it load tested.
  16. Try 6109
  17. Any fault codes? I think the cluster should be reporting faults.
  18. Try 5354
  19. Try 5305
  20. Try 3716
  21. OPC = Official Porsche Center In the US that would be your Porsche dealer.
  22. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  23. Not unless you remove the radio and the sticker matches (stickers do not always match as they are not changed after a repair). You will need radio keys to remove the radio - usually about $5 on ebay.
  24. Try 0763
