37,348 -
Days Won
536
Classifieds
Posts posted by Loren
Pretty much the brake switch and control unit.
Assuming there are no shorts to ground it is likely the issue is in the control unit. Many times control unit issues can be fixed by re- programming that module. If that does not work then a new control unit will need to be installed and programmed to your car.
The first thing I think is to make sure it is the stop light or tail light or fog light.
I would make sure it's not the fog light, also a bad headlight switch could also cause the issue.
1 hour ago, Milester986 said:
I have just bought a 2000 Boxster from my sister. We did repairs with battery disconnected. Now can't find radio code to operate radio. Have read LOST RADIO CODE First doc and retrieved serial #. Any help would be so appreciated, thank you.
Radio: CDR-220
Serial: Y5042538
Try 9014
1 hour ago, jimo55 said:
Hello -
I have a 2001 996tt with Becker CDR-220.
Had work don over the last few weeks and lost the radio set-up.
Serial number: 15089443
Any help recovering the code would be appreciated.
Thank youTry 3595
1 hour ago, Will Corder said:
Need radio code for
1999 Porsche Boxster
Type 4462
CD. CDP2081
48/98
Ser. X5025620
Please help me with the radio code
Will
Try 9604
3 hours ago, Bruce48127 said:
I recently acquired a 1999 996 and unfortunately did not receive the radio code or the PCM code. The car was optioned with navigation and a 6 disc CD player which were both removed. As seen in the attached photo, there are two labels on the navigation unit, one Becker (X5008025) and one Siemens (P08010010279/02), with different serial numbers. Does anyone know which one would be helpful in finding the radio code and if either one would help in recovering the PCM code?
From the Lost Radio Code FAQ....
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC." -
4 hours ago, Attila hun said:
Hi
I have the problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CD-22
type BE 4367
serial # W5005738
Thanks for your help 🙂
Try 4947
Yes, the required emergency release inside the trunk (red handle).
#17 is the emergency cable connect.
11 minutes ago, Dgelfuso said:
I could use help with a radio code:
2001 996
Becker
CDR-220
Type 4462
24/99
Serial 15063905
Try 0497
1 hour ago, verm said:
Need a radio code
99 986
Becker
CR220
BE 4462
series #X5016133
Try 9613
- 1
3 hours ago, LloydR said:
Hi, I’d be grateful if someone could help
me with a code for my newly acquired 996.
4362 y5024400
Thank you
Try 7281
2 hours ago, Rockstarc said:
Hi really need some help with this one,
Becker 1
Serial # X5036543
Try 5214
- 1
1 hour ago, Andre Holtshausen said:
Hi guys! Really need help here....I disconnected my battery
CDR-220
Serial # Y5047427
Try 6927
1 hour ago, Thomas felbo said:
Hi, do you have the code for a
be 7993
85006522
thanks Thomas
From the Lost Radio Code FAQ ...
"Which radios fitted to Porsche can have their unlock code recovered through serial number?
- CR-220/CDR-220 - Becker
- CR-210/CDR-210 - Becker
- Traffic Pro NAV/CD - Becker" -
3 minutes ago, Bruce48127 said:
Need the code for 1999 996 radio
CR210
Becker
R2095
serial# W5009715
Try 0109
Not sure how it is configured. If the resistance changes with the switch then the switch is likely okay.
5 hours ago, Matt A. said:
Than you. Please try serial: X5011535
Try 9180
You can use an ohm meter to see that the switches are working.
10 hours ago, Matt A. said:
Any other ideas:
Becker 1
type 4466
Serial: X5844535
6530 didn't work, thanks again 🤞
"The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
4 minutes ago, Matt A. said:
Unfortunately got the WAIT error on this one. Any ideas?
"I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again."
Help please: Brake tail stop light stay on
in 997-1 Series (Carrera, Carrera 4, Carrera 2S, Carrera 4S)
