  1. Sub assembly means a piece of the final assembly. Usually, Porsche only sells final assemblies (complete parts).
  2. Chuck, I'll bring my VOM and my electrical pin tools.
  3. My bad I think I was unclear. Right now when I set the alarm a get 2 blinks. I would like to get 2 chirps of the horn so that I know that the alarm is set. On other systems I have had it was just a dip switch setting to make this happen. As I said two chirps mean there is an alarm system fault. Having chirps is not an option on Porsche alarms - sorry.
  4. Two beeps means that there is a fault in the alarm system. You will need the Durametric Software, a PST2 or PIWIS tester to read out the alarm fault codes.
  5. I done 3 searches through the database of parts and there are zero parts in Porsche's (sellable) parts database that begin with 996.362. So, my guess is that is a sub assembly part number. We see that all the time on bumper parts.
  6. This the second time you have posted this. You need to read the reply here.
  7. Check for a loose wire at the sender or even a leaking sender. Both are fairly common.
  8. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST If the serial number on the screen does not match the one on your card then the radio has been changed out and the code is wrong. In that case follow the rest of the FAQ and I will try and guess your correct code.
  9. All possible wheel combination are listed in Porsche TSBs. Too many to list here.
  10. Take the 3 - 13 mm nut off the bracket and loosen the two 17 mm bolts ont he cat sleeves and the muffler tilt and come right out. Try it next time - it will save you a lot of time and pain.
  11. Try 9192 or 9190
  12. :welcome: 996.362.142.11 Turbo 2 wheel, MY03-on, 11 J x 18, 45 mm offset Perhaps you mean 996.362.142.03 Turbo 2 wheel, - MY02, 11 J x 18, 45 mm offset 996.362.142.11 replaced 996.362.142.03 so they should work equally well.
  13. Are you sure? I think the part in the way is item 17 (or 18 depending on the side).
  14. Folks please do a search - footwell lighting can be installed many ways and several have been discussed here.
  15. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. All TSBs are online here and available to view by Contributing Members.
  17. How about Santa Clara? http://www.wheeltechniques.com/
  18. Did you taker the mufflers off first? It really is a lot easier with the mufflers off.
  19. :welcome: Use only tire mounting lubricant and it will evaporate away one when dry/hot.
  20. Try 4583 or 4581
  21. We have a minimum $25 donation (mainly due to transaction costs). More info on donating here. What you get as a Contributing Member here.
  22. :welcome: How to become a Contributing Member
  23. Did you check the TSBs on this subject?
  24. Is a TSB a recall as well? From the Glossary at the top right of any page: TSB Technical Service Bulletin. Porsche issues TSB's for part number changes, installation of options and accessories, approved oils, tires, wheels, etc. Recalls are NOT covered in TSB's.
