  1. Try 9062 or 9060 Niether code worked, any further suggestions? Thanks, dsryan67 Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  2. Did you try the throttle adaption procedure the manual suggests? 1. Switch on the ignition. 2. Wait one minute. Do not press the accelerator. 3. Switch off the ignition for at least 10 seconds. 4. Read out the fault memory
  3. Try 9062 or 9060
  4. Try 4721 or 4719
  5. All 9x6 series cars came with the electronics for OBC (On Board Computer). But the feature was an option. If you got the factory option then you have 4 stalks on your steering wheel. The lower left stalk controls the different displays of the OBC in instrument cluster. All (US) 996 Carrera's came with cruise control - 986 Boxsters had cruise as an option. Both had OBC as an option. Yet the primary electronics for these were always "built-in" You can add both cruise control and OBC fairly easily to any of these cars. You just add the proper stalk(s) (or switches) and turn the feature on using a PST2 or PIWIS tester.
  6. Not far inside - just pull a little.
  7. You just push a small tab in. You might be able to see it with a flashlight. I usually just fumble around with it until the knob comes off.
  8. Try 1139 or 1137
  9. http://www.renntech.org/forums/index.php?showtopic=4732
  10. Check the drain tube on the AC - that is how the condensation escapes.
  11. Yes, if the bar activation is not "on" it will need to be turned on. If that is the case then you need to find someone with a PST2 oe PIWIS tester. You have to plug the two wire connector into a plug on the bottom of the seat (usually taped) AND the feature needs to be turned on with a PST2 or PIWIS tester.
  12. I agree they look like an OEM Mk1 bumper.
  13. I don't have a way to cross the sub-assembly. Maybe a dealer could by checking the numbers on their stock. Did the seller say what year/model car they came off of?
  14. Those are subassembly numbers generally not listed outside of Porsche. Do you have pics of the complete bumper covers.
  15. Where do you get the order type for any given vehicle? Thanks. We have compiled a list here
  16. In front of the spare tire on the bulkhead.
  17. I think you need to re-read Larry's post - the housing alone was $850 and the dealer comp'ed the labor. An exchange 6 speed for a MY01 Boxster is MSRP $4270.43 without the install labor. A new 6 speed for a MY01 Boxster is MSRP $7243.30 without the install labor.
  18. Try 4982 or 4980
  19. You could try to clean the connections on the egas throttle valve sensor. Or it could just be bad.
  20. I fixed this for Peter yesterday. The dealer should have know the model type code has to be in the DME to change any programming. The PST2 even has a warn message to that affect when you try to code something.
  21. 996.107.026.51 oil separator -- US MSRP $97.19
  22. Do you mean the clock spring for the airbag?
  23. Here is how I understand the "oil separators" use. There are actually 3 (what Porsche calls) oil separators. Two are in the sump and are used primarily to remove the air from returned oil so that when the pump picks up sump oil to circulate through the engine it gets oil and not an oil/air mixture. These are really swirlpots that defoam the oil. These are usually pretty reliable and rarely fail. (see item 4 below) The Air Oil Separator on the top of the engine is the common one to fail. It is used to take oil droplets (mist) and vapors (gases) from the crankcase and return the oil to the crankcase and burn the oil vapor in the engine (for emissions control). Most often the membrane in this oil separator fails and you get huge amount of oil sucked into the intake (and produce clouds of smoke). (see item 1 below)
  24. On MY02 and newer there is a returnless fuel system. On these cars the fuel filter usually does not need replacing unless the gas tank has become contaminated. "2060 Fuel filter The fuel filter is integral in the tank unit and no longer requires changing. A reduction in deliver rate can be detected via the mixture adaption."
  25. P0430 TWC Conversion, Bank 2 – Above Limit Potential causes: – Catalytic converter P11402 does not exist. If the CEL does not come back I would not worry.
