37,301 -
Days Won
530
Posts posted by Loren
Exact model and year of your car please - and what specific part(s) are you interested in?
1 hour ago, gerglmuff said:
Hello, this would be a life saver:
99 C2
CDR210
R 3297
W5019519
I found a 4 digit code written on some paperwork, unlabeled of course, 7522, but it doesnt work.Try 8787
You are likely going to need a shop with a Porsche PIWIS diagnostic tool.
Try re-training the windows. Hold the button down until the window goes down all the way - then do the same for the up motion.
If that does not work then there is likely a bad window regulator or other window/door issue.
2 hours ago, Urallan916 said:
Hey Loren thank you in advance!
2002 911cdr-220
becker 1
type 4462 or 4452
serial 25013184 or 25018184
my screen has dead pixels hence possible two numbers I’m pretty sure it’s the first sets 4462 and serial 25013184
Thank you so much!
Try 5486
1 hour ago, Drybones said:
5651 didn’t work unfortunately
From the Lost Radio Code FAQ...
"The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
4 hours ago, Drybones said:
Hello, request for a code for a CR-220 in a ‘99 996
type: 4362
Ser W5007097
Thanks!
Try 5651
46 minutes ago, Andrew Z said:
My radio now doesn't let me put in the code, it’s just stays in the wait screen so I can’t input the code, it’s been like this for about 15 min. Any idea on how to fix?
"I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again." -
34 minutes ago, Andrew Z said:
I have a locked radio box of a 2000 boxster from replacing a fuse. (I’m also the 3rd owner so no manual or card)
type 4462
serial number X5025157
CDR 220
Try 0810
2 hours ago, Porschenstein said:
I am working on rebuilding a salvaged 1999 996 C2
Radio is a CR-210
S/N: W5010462
Thanks,
Ron
Try 8786
- 1
9 minutes ago, Ryboor said:
ser 15004892
Type 4462
cdr-220
thank you!
Try 7132
- 1
31 minutes ago, waka76 said:
I can't figure it out... you tell me that the reference is 996.111.984.03 and 996.111.985.03. At the same time I have just received a response from Eisenmann who tells me that the only reference for a 996 4S is 996.111.984.05 and 996.111.985.05. And I have a friend who has a 996 4S with the reference 996.111.984.01 and 996.111.985.01…! 🤯 Are these not simply different periods of production? From what I know, the kit currently offered by Porsche is no longer necessarily manufactured by Eisenmann. So is the sound so good...? It's a mystery.
Yes, there was likely an 04 version as well as 05. Any version 03 to 05 should work on a 3.6 liter car.
if you are buying a kit - 000 044 200 19
Left Muffler - 996 111 984 03
Right Muffler - 996 111 985 03
1 hour ago, Vanishisam said:
My apologies, i missed a line, Model Number is BE 4462
Serial is Y5043704
Try 4651
If your car is a 3.4 liter then it does not matter. They both sound the same and nobody sees the tubes.
4 hours ago, RobO1 said:
Hi Loren - really hope you can help me with the radio code, thanks so much!
Becker, Indianapolis Pro
Model: BE 7950
Serial: 85028730
Version: Europe
30/08
Try 1243
9 hours ago, darren26 said:
can you help me please on this radio
BOXSTER VIN NUMBER wp0zzz98zyu640103
PORSCHE BOXSTER S 3.4 (987 GEN II)
2000 S
CDR-220
Becker 1
Type 4467
Ser # X5020497
24/99
GAL 00
CDP2081
Try 9076
13 hours ago, Abattle305 said:
Hello, this radio is in a 993 I just purchased
CDR-210
Model: BE 8567
SN: S1002001
Try 9813
The small tube versions were likely out of stock 10 years ago.
6 hours ago, StrokedAndBlown said:
Hi, Loren - I just got a new battery and can’t find my code card. Long time member here as 986ster (but account was reset) and on 986forum as Stroked & Blown.
CDR-210Model: BE 2282
SN: W5021066
Try 0438
39 minutes ago, Johnson said:
Hey Loren,
l need your help too.
model number BE 4462
serial number 15063724
thanks for your help🙏
Try 8295
13 hours ago, Branden Dunn said:
Trying to get radio code for my 2002 boxster.
Model No.BE6624.
Serial No.15005181
Thanks in advance
Try 2102
23 minutes ago, RobbyG said:
Can anyone get a code for:
4462
48/98
5033561
Thanks 👍
Try 9108
Sensor under right exhaust manifold on 3.6 V6?
in 92A (Cayenne, Cayenne Diesel, Cayenne S, Cayenne Turbo, Cayenne S Hybrid)
Exact model and year please...
