jyoteen
Everything posted by jyoteen
  1. I'm pretty sure someone over tightened the bleeder valve the last time the brakes were bled. They shouldn't be really all that cranked down.
  2. It´s total, 100% sure. If you are interested about the wreck, make an offer to the insurance company. In this kind of cases, they would, quite sure, accept few thousands of $. wow, what year is that car and how many miles? I'm asking because there is a large probability that I'll need a 3.6 engine, and well, if it's totalled, then it may be worth it.
  3. Iback: Your profile does not say where you are located. If you are in California, your dealer may be relying on the state law that only mandates coverage for 7 yrs/ 70,000 miles. However, federal law (specifically The Clean Air Act, which can be found at 42 U.S.C. 7541) trumps any state law and requires coverage for 8 yrs/80,000 miles for the catalytic converter, electronic emissions control unit and on-board diagnostic device. A manufacturer may not refuse warranty repairs under the Clean Air Act's performance and defect warranties, unless it can prove that an aftermarket part is RESPONSIBLE for (causes) the warranty claim, so don't let them give you any of that B.S., either if they try to go that route. Take a look specifically at subsection 7541C (3) b. of the Clean Air Act for the language relevant to your defective cat. You might want to print that section and educate the dealer. Good luck, and let us know how you make out. Regards, Maurice. Profile needs a bit more work I guess..lol. In Canada. Seems Canada has same laws as US 8yrs/80 000M or 130 000km. Not sure why they think warranty is over..they are original cats. Hi there. I have a 2003 C4s with currently 90K miles. I had my catalytic converters replaced THREE times. Yes, that's 3 sets. Just recently, The last set went at 81K miles, which is exactly 1K miles over the Federal emissions warranty at 8 years/80K miles. Call Porsche. They covered it gratis, because I told them that this has been a problem with my car. Exhaust develops a rattle and it shakes the innards loose of the catalytic converters. Off the record, the technician told me that he replaces a lot of them, so it's definitely an issue. Good luck.
  4. Welding and filling and painting. Thanks ,but can it be done the dealer tells me that the support panel underneath is different on coupe ,turbo and gt2. i think it can be changed as its a cover really ,on the 997 its bolted on with 5 bolts. but is bigger than the turbo 996 panel looks welded to me.
  5. the turbo decklid and the c4s decklid are different. The difference is that the piece right below the rear window is narrower on the turbo. I bought a complete rear turbo decklid and it was pretty obvious that it'll not fit. To make it fit would require lots of surgery, so your best bet is to go 3rd party solutions.
  6. yes, I got renntech aluminum mats. No more sliding and w/ the aluminum pedals, looks great. I got so fed up after buying OEM mats and the mats sliding around.
  7. I think if you get one of those 9volt cigarette lighter things from autozone, etc, you don't have to do anything. AAA changed out my battery when my car refused to start not too long ago, and they used this gizmo so no CEL, etc.
  8. 83k miles on a 2003 c4s. It's truly my one and only daily driver and so far the only issues have been catalytic converters. I'm on my 3rd set, all covered under warranty. Also RMS failure when the car was in the 25k mile range but otherwise I have no issues with the car.
  9. You can contact Stoptech to see if they'll sell you individual pistons/seals. http://www.stoptech.com/
  10. You know, I know it's a popular mod and a lot of folks have had overheating issues (maybe '00 specific), specially on the track, but I've NEVER had overheating issues, let alone high temps in my car with the standard 2 radiators, even on the track during the middle of the summer at places like Buttonwillow and Thunderhill, which get 100 degree temps in the summer ambient. I will say though, every time I wash the car, I spray high pressure water at the radiators to keep them clean. Oh, and it's a C4s.
  11. On Thursday, my temp gauge decided to not function temporarily. The needle was buried at '0' and the red light was flashing away accompanied by a warning on the central display. I should have snapped a picture, but oh well. I restarted the car at the traffic light, but proceeded to have the same malfunction. This is, I guess 'lucky' since my CPO warranty runs out this week. After some time on the return trip, the temp gauge worked fine. Now, I wonder if the circumstances of parking on an uphill incline, at an odd angle with it also leaned to the right due to the nature of the uphill, would cause this malfunction (coolant temp sensor). I don't have any leaks either and the coolant level is ok. I've religiously purged the coolant 3 times already (once every year and a half) at 30K mile intervals. What could this be other than an instrument cluster failure? Also, would a more permanent DTC be recorded in the car's computer, since the light/malfunction is no longer there? Thanks.
  12. Seems mine is cracking and it's a rubber part. It's been mentioned to me that Porsche used to sell this separately but now you have to purchase the entire driveshaft? Doesn't sound right but who knows. Part numbers/Diagrams/Photos most welcome. Is this a wear item? Car is under CPO and currently has 78K miles.
  13. My main problem is the HORRIBLE OEM mat retaining system using those velcro pads. My plastic disc that goes into the carpet has been ripped out so I must put up with adjusting my mats every traffic light. The OEM mat backing material gets stiff over time. Anybody have adapted a mat or are aware of another way of mat retention? I had an Audi and it's snap in holes on the mat worked infinitely better. thanks.
  14. Callas Rennsport recommends 93 ft-lb on the bolts and around 53-56 on the wheel lock bolt because of the aluminum. That's what I have and it has no problems.
  15. relax. I was just being a smartass. I secured a Turbo OEM Speed Yellow painted Tail with the hydraulics for $700 off ebay, so I was figuring it'd take at least $1K to do the install if it involved any bit of modification to that metal strip + paint. There are mods that are worth the money in my book and ones that aren't, and there's a cost associated that goes over that magic checkpoint of feasability. Unless you have endless funds, I'm not so sure it's 'worth' it. That's all. :D
  16. On that note, can a Carerra GT lump fit a 996 C4s? I want more power.
  17. my car consumes about 1 qt every 1K-1500mi. My VW and Audi both consumed 1qt every 1K miles, and per manufacturer, that is normal. Although, you gotta wonder that since the oil change is every 11K miles, why do a complete flush as the original changed oil would have completely burned off. I have no leaks, but I don't baby the car at all.
  18. No way. Unless you're willing to cut sheet metal. I bought an OEM Turbo tail and decklid with hydraulics complete for the C4s, but quicly found out that the part right below the backlight before the rising wing is different in height between a normal C2/C4s and the Turbo (where the 3rd light is). On the C2 variants, that part is much taller (maybe due to the need to accomodate the 3rd brake light). There is no such beast on the Turbo as its third brake light is on the secondary wing. And unfortunately, this part on the C2/C4s is metal. And it's not bolted, but welded, so you'd wind up spending over $1K to affix a wing. Oh, and even though the turbo wing provides downforce (I think something like 30lbs), you'd have to lower the front end to balance out the aero, either with a GT3 type lower lip or physically lowering the car and adding sideskirts, aka Aerokit.
  19. I'm doing it today, of course, if the rain stops for a couple of hours. It's no big deal in terms of helping me. I've swapped out tons of brake pads on Audis and even calipers. I just basically wanted to find out what tools I need before I start tearing in to my only ride to Home Depot. hehe. Oh, I'm located in Highland Park/Mount washington area, and headed to the track tomorrow (Buttonwillow) Thanks!
  20. Does anyone have an image from the tech manuals on removal/installation of the front rotors for the C4s? I got replacement OEM ones. I think I've taken off the calipers (long time ago) but forget the tools necessary, but most important of all the torque specs, if they're specific for the screws. I'm hoping that the screws aren't jammed. do I use anti-sieze on the hold down screws? Are they really needed? I doubt that, but just making sure. Thanks. Jyoteen
  21. it's the variocam profile switching over at 3250 rpm. I have a 03 C4s and I can replicate it at will. I doubt it's the egas because it doesn't happen when you accelerate rapidly. It only happens when you are coasting and then decide to accelerate. The cam's duration/lift changing would explain the change in the power curve and the not so subtle engine output.
  22. are you talking about the city lights? That's a european thing (similar to parking lights).
  23. Just got the notice in the mail on Friday for my 2003 C4s (build date is around December 2002) ------ Recall A309 Model Year 2003 Porsche 911 Carrera Dear Porsche Owner: This notice is being sent to you in accordance with requirements of the National Traffic and Motor Vehicle Safety Act. Porsche AG, the manufacturer, has decided that a defect and noncompliance relating to motor vehicle safety exists in certain model year 2003 Carrera vehicles. Our records indicate that your are the Owner of a Porsche 911 Carrera type vehicle involved in this recall campaign. Unfortunately, front seats were fitted to your Porsche [stock power seats] that have seat backs that due to the supplier's manufacturing error do not meet the strength standards demanded by Porsche. In a rear-end collision, this can lead to the seat backs of occupied front seats tilting on one side to the rear, increasing the risk of injury to the seat occupant. In order to avoid danger to occupants in a rear-end collision, both of the front seats must be replaced. Please note Federal Regulation requires that any vehicle lessor receiving this recall notice must forward a copy of the notice to the lessee within ten days. You should arrange for an appointment with your Porsche dealer as soon as possible to have the required work performed. The parts (new front seats complete) have been produced exclusively for your vehicle according to the original interior upholstery color combination. The parts are in stock and will be expedited by your Porsche dealer of choice upon your contact. The necessary tools to perform this recall will be available at your Porsche dealer. The estimated time to perform the recall campaign is approximately two hours. Please allow yourself and your Porsche dealer additional time to perform the repairs. If your Porsche dealer is unable to perform this repair within a reasonable period of time, you may call or write: Porsche Cars North America, Inc. 980 Hammond Drive, Suite 1000 Atlanta, GA 30328 Attention: Customer Committment Telephone: 1 (800) - PORSCHE You may notify the Adminstrator, National Highway Traffic Safety Administration, 400 Seventh St., S.W., Washington DC 20590, or call the toll free Safety Hotline at 1 (888) 327-4236. We sincerely regret any inconvenience this recall campaign may cuase, and hope you understand our interest in performing this work promptly so that you can be satisfied with your Porsche automobile. There are no costs to you and the repair is free of charge. Please accept our apologies for this unplanned service visit. Sincerly, Porsche Cars North America, Inc. -------------
  24. So, as some of you know, my ContiSport Contact 2 are shot. I noticed yesterday that I have cords showing. No big deal....time to replace them. I was going to go with a set of Toyo RA1 because I can get one set free at this time. Cool. I was set on getting a set of RA1s all around, until I noticed that Toyo doesn't list a comparable size to the 295/30 width found on the C4s. The 2 closest potential candidates are 275/30 and 335/35. Now, the 335 aint gonna fit. Too wide. The GT2 has 315 wide tires, but that's the max. I was hoping that the 275 may run a little wider since it's an R compound tire, so I can go with that. Toyo also has a 305 width coming out, but seems that has been postponed. My contact at Toyo emailed me the following: So......am I screwed using Toyos? Crap. Trying to find circumference and other data on the Contisport Contact2 to figure out if I'm even close with any RA1 line. Thanks. Jyoteen.
