juniinc
Everything posted by juniinc
  1. If they are H7 halogen,,, try not to touch it with your bear finger or any oily residue.
  2. there could be too much tension against the rear,,, slide it a bit forward then see what happens. Yes there is a way to trouble shoot this, but U'll have to remove the seat first.
  3. Radioshack should have some,,, yes there is.
  4. +1 on Nexen tires,,, app 16,000 miles on my N3000, still close to 8/32".
  5. DIY, U can do it! http://www.renntech.org/forums/index.php?/topic/16350-new-rear-window-installed/page__p__81595__hl__%2Bnew+%2Bwindow+%2Binstalled__fromsearch__1#entry81595
  6. U need a pin removal tool,,, http://www.renntech.org/forums/index.php?/topic/33367-seat-wiring-question/
  7. by-pass the level sensor,,,easiest way to find out.
  8. Any chance? your car has been sitting for a while
  9. Anything is possoble, yes can connect it to your tail lights,,, I would check the bulb first!
  10. Sure thing, man. looking forward to see your work,,, Try to post some pics as U progress, would be a great write up.
  11. http://www.renntech.org/forums/index.php?/topic/13475-radio-problem/page__p__66657entry66657
  12. time to start a class action lawsuit. Rescently the lawsuits were filed on behalf of owners of GM vehicles, which were factory-filled with Dex cool coolant,,,They won. http://www.girardgibbs.com/dexcool.html
  13. Sure Mark. That would be your illumination/Switch LED Leg,,,
  14. Your coolant light is blinking slowly,,, Check if your engine compartment fan is kicking on.
  15. Any code? check the fuel pressure regulator,,,
  16. Usually due to a slight mis-alignment. Can U tell any gaps between the spoiler and lid (on each side)when its down? or one side slightly higher than the other,,, Often times need to re-seat,,,
  17. Try campbell Nelson VW used parts in Seattle,,,
  18. Drive her like U just stole it,,,
  19. There are some stop leak stuff out there,,,supposed to make the seals swell & at the same time probably ruining some other seals. Auto or manual? your clutch replacement job coming up anytime soon?
  20. driving a almost factory tuned race car, have to compromise in somewhere,,,
  21. most likely it's the starter solenoid or starter relay,,, I would start by checking the ground strap, battery connection, solenoid connection
