gchu
Everything posted by gchu
  1. Even the delay & hesitation problem is fixed last month, but the car still doesn't feel right. The transmission always feel like at the wrong gear at different speed when accerate and doesn't shift when it suppose to. My dealer called me yesterday and the parts for the new recalls has came in. One of the item they will replace is a update transmission control unit. I will bring the car in a week later. Hope this will address the only problem I have for my 05 CS.
  2. Watch out that bulb once it has been on for a while. It is very hot. I burned my finger last time when I touch it.
  3. Kirby, I was planning to do it this afternoon but went in to couple problem. First I can't get power from the fuse box like becuase #48 is used by my air suspension. I also want to install a FM modulator as well and found the antenna adapter I have doesn't work with the PCM. I think I will just get the power from the PCM to power the FM mudulator & V1. I checked this after and found out once the right side fuse box open, it is very easy to run the wire from the A-Piller to the rear mirror. I will wait for the antenna adapter arrive and do both later.
  4. I check #48 is not available. It is used by the air suspension which I have. I need another fuse location. Any suggestion before I do any trace.
  5. I found out my Cayenne S has that after had it for a while. I was confuse when I first notice that until getting use to it.
  6. Here is the link of the DIY. http://www.boltonwebster.com/cayenne/removalfrontapron.pdf
  7. I order mine few weeks ago and asked my dealer to see if there any instruction with the kit. The answer was "no" for the mud guards. The kit seems to have more screw that it needs. I found there are marks at the wheel well (either front or back, no both) for the holes to be drills. I was thinking to put mine on this weekend but it seems better with the wheels off for the hole drilling. Maybe few months later when my tire need rotation.
  8. The dealer who sold me the kit sent me the bumper removal insturction. Thanks for all the help.
  9. I took my 05 CS to my dealer yesterday for the acceleration delay problem. The dealer found the problem is from a loose connection at the air mass sensor/kickdown adaptation. My CS has no more delay and has very good response now . The gas pedal feels different than before too. I don't know is this the same problem for most of the 03 & 04, but my delay problem has nothing to do with the software or control unit. By the way, my car had this problem very first when I got it with less than 10 miles. The service manager said they should catch it during the factory inspection. I am starting to worry about Porsche Cayenne's quality control.
  10. This morning I tried to install the skid plate as insturction provied by SANDOVAL. I can't get the front bumper to come out. I had all the screws removed, the wheel well, under the bumper, & top of the bumper under the hood. I just can't find the lever that SANDOVAL decripted in his instruction. I stucked and finally put everything back together. SANDOVAL, did you take a picture where those levers locate? Anyone, please help if you have the bumper removal instruction. I don't my 05 bumper is any different to 04. Thanks.
  11. Does anyone know how to keep the radio off when using the PCM? Everytime I turn on the PCM for map, the radio or CD automatic turns on and I have to mute it.
  12. I can only find the wire & fuse location for hardwire the V1. I am more interest in remove the A-Pillar trim & the PCM. I want to see if any one has instruction to remove those components before I attemp to figure out.
  13. I can't program my new CS's Homelink to my Genie garage door opener. It is a 2 years old Genie Intellicode garage door opener. I had no problem with my other cars' homelink except the new CS. I reset (erase) both the garage door opener receiver & the CS Homelink transmitter but still not able to get it to work. I checked the manual and it seems no different to program as the other cars. The CS works with other brand garage with dip switch remote but just can't work the the Genie Intellicode. I tried both garage doors and the problem is not the garage door opener. Do you guys have any problem with Genie Intellicode? Any trick? or time to the dealer? Thanks for any help
  14. :lol: After over 4 months of waiting, it is finally here. I drove 3 hours from the Bayarea to pick it up at Fresno. It's a 05, so far haven't noticed any problem report like some 04, no vibration at speed near 60-80 mph. Had some problem using the remote key and the rear window, just need to read the manual later. So far, I only get 15 mpg at freeway & 11 mpg for city. Hope this number increase after break-in. with the 19" Cayenne Wheels My new Cayenne & SY C4 Cab My new Cayenne & SY C4 Cab My new Cayenne & SY C4 Cab The lowing setting for the air suspension. Yes, I know, where is the clear side makers. The highest setting for the air suspension.
  15. I am trying to hardware the V1 in my Cayenne like my 996. Is there any DYI out there? The A-pillar in the Cayenne is the side airbag. So I don't want to take a chance and try to remove the trim. Thanks in advance
  16. May I ask what does the EVO shift link do? Thanks.
  17. I would like to hear it but have to wait till after I pickup my CS sometime next month. Thanks in advance. Enjoy your new mod.
  18. Very nice Kirby, do you feel any different in sound or performance? I bet the sound got to be different for that price. How much does Akkurat charge you for installation? In the near furture, is it possible for me to check out your mods becuase the bypass is one of the item on my wish list form my coming "CS". I would like to hear it personally.
  19. The unit at Cruthfeild, is Harman Kardon the same as Becker unit?
  20. They damaged your OEM top and they own you an OEM top. Why would you have to pay the different to the after marker. If the insurance only cover the after maket top, the suspension shop have to cover the rest of the cost.
  21. Mine does that once a while. Not very loud but only a little squeal.
  22. I say it is a must option for a cab. I use mine all the time for my 02. If I want more wind, I can flip the screen down. For the price, I have seen dealer selling it for less than $300.00. Good luck.
  23. Can someone tell me is the same jack pad to use for MY02 or newer? I think the jack point for the pre 02 has a hole to fit the jack pad. My MY02 doesn't have the hole for the jack point.
