tsweat
Everything posted by tsweat
  1. Thanks for the good info, I posted a similar question a while back and still have the same issue... What if the window is not dropping at all, and also the "one-click" up/down will not work. In addition, when using the window switch in 'manual' mode it only moves 1/4" then you have to release and repress again and repeat until window up or down? :help:
  2. Thanks Izzy, I will try it out tonight if time permits. Once again, great write-up and thanks!!! Tim
  3. Good-day Izzy- It sure seems that our car's are sisters....as they keep having the same issues. :help: My top is now acting up and stalling in either direction. The motor is running, but sounds "louder", so I am thinking that this may be due to low hydraulic fluid as you mentioned in the post. This weekend, I plan to try out your method. I have a few questions... First, my stereo takes up the backseat area and is a pain to remove. It sounds like you are able to access the reservoir from the rear area (where the floded top sits). Is this correct? I do not need to remove the panel just behind the rear seats?? This would be great news! Second, Is this on the drivers side, or passenger side? Are there "fill lines"?? Third, fluid -- any ol' hydraulic fluid will work you think? Fourth, ever take any more pic's?? As always, thanks!!!! -Tim
  4. Izzy -- what did Sunset charge for the FOB's and how about the dealer programing fee? Thanks! Tim
  5. UPDATE WOW, what a difference this made. When I bought my car 2-1/2 years ago, the bonnet (trunk lid) popped up as I thought it should. Slowly over time it got worse until it would not work anymore and even triggered the alarm 'beep' fault. Today I finally got around to using Viper's tutorial and was amazed with the level of success. Not only did I save myself the time and money of going to the dealer, but the trunk lid now pops up with authority and a good two inches higher than it did when I bought the car. Thanks again to all who helped me out on this one!!! Bravo!!! :clapping: -Tim
  6. Wow...searched worked! :) Any updates on this? My 99' 996 Cab is starting to do this on the drivers side door. Also of note, the window will only "move" in small increments when using the window raise/lower switch?? I unhooked the battery to see if it would reset anything and seemed to help for a day or two, but now its back. Any thoughts? I would like to repair this issue myself if possible.... Thanks in advance!!! Tim
  7. Great Write-up Viper. Thanks...I will be using it this weekend. -Tim
  8. UPDATE It has been 700 miles (took a road trip to Austin) since I cleaned the MAF and replaced the air filter. So far, so good -- no Check Engine Light and no funny business. Hopefully this was the culprit (knock on wood). If anybody has questions about the process, or what I did, let me know. It was all fairly straightforward. -Tim
  9. Thanks for the heads-up Izzy. Mine is a 99' model and maybe it has just worn out as you suggest?? This weekend I will fiddle around and see what I find out and post the results. Thanks again! Tim
  10. Adjusting the Hood Latch Mechanism Eureka! I suppose during the time you guys were typing, I was arriving at the same conclusion. I pulled the latch mechanism out and examined it up-close. The tension spring was out of a pocket on the latch and not providing any push when the latch was released. Hence, the hood could be pulled up out of 'battery' but would not pop up on its own. I disassembled the mechanism, lubed it, and re-inserted the spring into the latch. Put it back together and now all is well. Very simple to do. This Author viper501 Category Carrera (996) - Common Fixes and Repairs Submitted 07/06/2005 08:16 PM Updated 03/17/2017 05:12 AM
  11. Split. Check your PM. Are you here in Dallas (Valley Ranch)?
  12. Hello All... I have searched and read all questions and responses regarding error codes from check engine light notices. All provided insight, but I am still confused on what plan of attack MY SITUATION calls for... First off, I posted a note many months ago when the first CEL came on, inquiring about a dirty air filter and if that could be the culprit. The light went away, so I figured no harm (filter seemed as though it had some more miles left). Fast forward to now, and the CEL has been flickering on-&-off for about the last month, (I don't drive it that much). So this weekend, I checked the code (and cleared). I am receiving error code P1125 (Scan tool read out 'Fuel Air Metering Control'), Loren's list reads this code as (Oxygen Sensing Adaptation Cylinders 4-6). This is the only error code listed from the scanner. First Question: Cleaning the MAF Sensor seems fairly straightforward, is there any way that, if careful, cleaning can cause damage to an otherwise healthy sensor? Second Question: Could it in fact be my first guess months ago of a dirty air filter that needs to be replaced? I will be replacing filter tomorrow regardless. Third Question: Code is cleared, but will disconnecting the battery for 20 minutes "reset" the computer calibration for fuel/air mixture in case cleaning of the MAF and new air filter rectify the situation? Thanks in Advance!!!! -Tim
  13. Replaced mine myself. Under $10 part, and SIMPLE. The only hassle is removing the console, but that is fairly easy as well (just time consuming).
  14. Could an air filter that needs to be replaced cause a Check Engine Light to come on? Just a standard air filter, no mods done to the system. Thanks! -TS
  15. Great info once again!! Thanks Loren!! It really puzzled me (and worried me since mine is out of warranty). -TS
  16. You can try e-bay -- but there is not too many wood parts there. Its mostly silver & carbon pieces. You can try these guys. I have no experience with them, but was considering having them do the carbon look after I found them on e-bay. Classic Trim
  17. Two questions then... 1) So what is the 'danger' in not correcting the RMS if it fails? As, long as the engine has correct levels of oil, what can/and does go wrong? 2) Does the RMS failing cause the Check Engine Light to come on? Thanks! -TS
  18. This is what happened to mine. Simple replacement of a $5 part...
  19. A few guys over on 6-speed have installed it with success in their 996's. I am going to give it a shot and will let you guys know how it works.
  20. Thanks for the insight. I was not sure if you could purchase on the open market a timed relay, etc. Let me know if you get around to the implementation stage anytime soon. :) I may break down and spend the $99 and not worry with the hassle...
  21. Has anybody tried building their own relay for a "one touch cab-top" function? I know the following company has done it Bahn Tech Autotop, but it does not seem that it would be too terribly difficult to make your own. Any thoughts on how to go about it?
  22. I used the thread that Loren linked to... Since I have a cab and use all four slots for the windows I put the same (door lock/unlock) switch in the spot that you are wanting to use -- where the PSM goes. Mine works great and is actually much easier to access by just popping off the upper console. There is plenty of room behind there for the garage door opener to fit. Let me know if you have any questions... Tim
  23. Not to hijack the thread fazzyb, but I too have a leak I would like to see if anybody can identify... Any idea what kind of leak this could be? The photo was taken while I was changing the oil yesterday so please ignore the obvious dripping and splash marks. I am referring to the soiled area near the corner.
  24. Yep, that was the culprit. I replaced it today and did the hack for the speed control. Now my top works again and I can move it up & down while the car is in motion. Pretty cool! Thanks for your help!!
  25. Any update from you guys that did the speed sensing mod, that has now also done the e-brake bypass altogether? The reason I ask is that for some reason my e-brake engages just fine, however the light (and whatever sensor it hits) does not engage and does not let my top go up and down unless I use the key in the door trick. any help is appreciated... Thanks, Tim (long time lurker here at renntech and poster at 6-speed...)
