judgejon
Everything posted by judgejon
  1. Do you notice any noise or vibration now? I used paper matches, heads removed, to deal with a bass speaker vibration issue once, so the rubber gasket thingy is not out of the question. Hope you consider this a “solve.” Carry on...
  2. Are there any loose tube or small hose ends down in that area? Looks like a hose or tube connector that fits in a hole in the frame or in a metal brace to protect a tube going through.
  3. All modern cars, sure. But not my point. I don’t think anyone would make a kit to do a conversion. It’s all a do-it-yourself project. Good luck. Don’t hit anything head on.
  4. I had a similar Momo on my 911sc. It was a Momo “corse” with a Porsche emblem horn button. I do not believe you will find any commercial adapter kit for a 996. To put on a Momo-style wheel you would have to disable and remove the airbag. Too much liability for any manufacturer to put anything like that on the market. It is a do-it-yourself all the way. It’s very unlikely any reputable shop would even help with the work. imho of course.
  5. I occasionally noticed same gunk on my 911sc. With 996, think it’s especially important to always allow engine to reach op temp before pushing up the rpms. Also, unlike the older air cooled engines, the 996 is not, imho, meant for quick trips to the market. Once started I think it’s best to drive the car easy until thermostat opens up. And then drive it with a little emphasis. In heavy traffic, if engine properly warmed up, and fans working, temp should not raise dramatically. Joe is right on the money. Good luck. Hope this is an easy fix.
  6. Forget it. Use the friendly search engine. Lots of stuff on this. Is this mostly a random unknown cause Issue? Bottom line , imho, is to get a Durametric and a nice laptop to take on road trips. When you get a random airbag light just clear it. If light does not clear, or immediately returns, then check it all out as you mentioned. I’m sure I read somewhere on the forum that the seatbelt light issue is a known quantity. Good luck.
  7. Cdr 23 Becker? This happened to me all the time. Fix was to turn off and restart car. Sometimes more than once. For sure an early death of ignition switch. A Porsche mystery I never really solved. I think it’s weirdness built into radio.
  8. I’d bet they are the same, depending on the model year. I’d guess C4$ would for sure be the same.
  9. From past experiences, I think you will likely find it easier to replace the entire module. But you found the 996 solution to overdriving your headlights without constant hi beam/lo beam flicking. Set the lows up just a few clics. “Back in the day” with older 911’s the trick was to replace the Bosch low-hung fog lights with real driving lights or to remove the internal lamp shrouds. Problem either way is you might get some blinks from other irritated drivers or attract a LEO. Have to balance that with your driving pattern..ie, lots of night driving on twisty mountain roads? Easiest solution is just replacing the needed headlight module. Good luck.
  10. Good point. But would that produce the complained of noise? I still love Mysterious Porsche Mysteries.
  11. Did you wash up into the undercarriage with car up on rack and wheels off? my guess is accumulated road salt. J'espère que vous comprendrez.
  12. Very weird, but possible if car driven in cold country with rock salt on roads for melting ice. Where are you located? Ever hose off underneath chassis and up into suspension? That said, not sure if water from garden hose would even get up in there. High pressure hose with car up on rack maybe. Good luck with all this...better stay off the track until replacement accomplished.
  13. Right on re sound travel. I was thinking shifter linkage, cables, etc, anything, something carrying sound up along center hump to front end. E-gas too, right? So no throttle cable rattles. Jeff is great source. good look with this mystery. Post up answer for us curious types.
  14. The posting of your links needs to be cleaned up. But, not sure how, I did see video and hear sounds. Bizarre. Only thing that initially comes to mind is that sounds are somehow travelling up along clutch cable. Not even sure that’s possible. Is pedal secured? Is cable from clutch ok? I don’t think there are any pulleys in front of firewall. Mystery. Good luck
  15. Like sometimes happens with questionable sellers on Amazon, I’d bet you purchased a cheaply made knock-off of the key fob. Blade probably not the issue if laser cut looked close to original. We had a key go missing once due to a purse theft. Had to order from stealership that in turn had to order from factory. Yeah, big bucks. Good luck...
  16. Try pulling cables, cleaning connections, then reconnecting. Could be a spot of corrosion on battery posts that restricting voltage. Hope you can avoid the tow...
  17. Oh yes. We all have stories of bolts that were not properly torqued and other horror stories from service work poorly performed. I was fortunate to have a very good Inde shop in town.
  18. Agreed. Check the belt. I had always made a point of changing belt if any engine work done. Likely overkill but... This sounds like belt slipped. Maybe due to wear at a “tooth?” good luck.
  19. Yup, me too. Esp on curvy highways over the mountains. Oh yeah. In the C4$ torque tremendous in all gears. “Every now and then” when you drive a Porsche you just yield to the temptation. And, you get a valentine 1 and hard wire it in.
  20. Silver C4$. I smiled each and every time I drove my 2003 C4S. Make that C4$. It costs to own and operate. It’s not cheap. If you can DIY that’s even better. Be sure to do the IMS “solution” etc right away for piece of mind. Enjoy.
