SH-GT3
Everything posted by SH-GT3
  1. I'm assuming this is oil pressure and and not level. Bad sender/sensor?
  2. I've only been a GT3 owner for a couple months, some people have installed home-made screens, but I wouldn't spend too much time worrying about it.
  3. I'm almost positive there isn't any mesh installed from the factory
  4. Nice. Well there you go achillies. :) The Locktite 5900 is what Suncoast sells. No leaks.
  5. Could you post up your reference doc or source? I could not find any documentation for the install. Its not even called out in the X51 documentation.
  6. I found what I was looking for, thank Loren. :)
  7. Thanks Loren. Upon some deeper digging I’ve been told there is a race pad application and a street pad application for the Gen 1 PCCB setup. What about these? Street PCCB Pads 980.351.939.00 (front) 996.352.947.03 (rear) Is there only 1 set of brake pads available as replacements?
  8. I have found a number, but cannot locate them within the PET or on a couple parts sites 996 351 940 92 Front Axle Brake Pad Set 996 352 930 90 Rear Axle Brake Pad Set ???
  9. I tend to agree with lenobleb If you are really concerned about it, get two more ramps and drive up on all 4 :) Level, and plenty of room to work underneath safely. I do this with jack stands, or on a friends lift.
  10. The ability to misalign the shifter cables and the adjustment set screw on the shifter itself during install IMO is pretty high, which why I think some folks says it notchy, while others like me think its perfect. JMHO
  11. Basically on top of the cats. I doubt this is the problem, but its worth ckecking.
  12. Make sure your 02 sensors are still screwed in tightly.
  13. I recently installed the B&M and absolutely love it.
  14. HERE are a few of my pics; link to instructions also there. Its pretty straightforward. :)
  15. Interesting Jon. This is your motor? Any more pics?
  16. Since I am fairly low this is exactly what I do to get the rear up in the air in one shot.
  17. Recommended snow tire sizes are detailed in the OM. I'd call TireRack, or use what Dennis used.
  18. I used that special last week; got a $20 K&N filter........for my 94 Geo Prism. Only OEM Porsche filters for the C4S
  19. Can you please post it? How many data points / samples do you have trended?
  20. Just be careful not to get too budget oriented when doing your brakes. :)
  21. Get the stock replacements and paint them "fancy" gold. :P Seriously though - what do you mean by fancier?
