bigbuzuki
Everything posted by bigbuzuki
  1. Don't go driving the Cayenne turbo, it will only make your decision just that little bit harder.
  2. So does the compressor actually work, can you raise and lower the suspension? The fault message 'Air Suspension faulty workshop' can be caused by a low capacity main battery. I had the same message a couple of years back. My main battery was 5 years old then and when I replaced it the fail message has not reoccured.
  3. The fuel tank vent line comes with the check valve as one assembly. Part # 948-110-202-01. That's the one that was causing the poor start on my CTT.
  4. Could be the air compressor running if you have air suspension.
  5. Check out fuse F50 on the fuse carrier, dash panel on the left.
  6. Forget the rest, go with the best. www.porscheoemparts.com has them for $198.05
  7. Think of it this way, If your in the car and doors are locked whilst driving, the rear hatch can't be opened from an intruder from the outside. If you did want someone to open it, you would unlock using the inside hatch release button then the rear hatch can be opened via the external hatch switch.
  8. The rear lid will only unlock when using the internal release switch or when pressing the unlock button on your remote. You still have to use the external lid handle to open it in all cases. The popping open of the rear window after pressing 2 secs on the remote is normal. The owners manual illustrates this. Nil door chime and turning signal sounds like a faulty speaker / circuitry. I think it lives in the instrument cluster.
  9. +1 on the drive belt especially if you've got > 70,000 miles.
  10. Coils / plug issues for sure. Also ask your brother in law if his Cayenne is a Turbo S. Turbo S Cayennes did not exist in 2004. They were born in 2006.
  11. Catch 22 really. My 2003 CT is still under extended factory warranty until the end of 2012. Although the Redline products claim to be superior to other manufactures oil specs, the fact remains that they are NOT listed on the Porsche Approval List for oils. Therefore I won't risk using any oils that don't appear on the list, as I would void my warranty. Once out of warranty, I will take another look at the status quo.
  12. Could be the vacuum pump for the brake booster if your turbo charged.
  13. www.porscheoemparts.com sells the oil for $34.58 per litre.
  14. Lights will go out after a lengthy period of time with the a door open. This is a normal power saving function.
  15. Mine had similar start up problems that you describe especially when the unit was cold. Unfortunately the PCM has been known to have these issues and mine was a bad solder connection to one of the ICs on the circuit board. It could be a solder issue, requiring a new / exchange PCM, or you can try this
  16. The PET has the compressor for the 2003 model (part number 95535890101) priced at $1454 AUD incl GST for the Oz market. There is a 95535890104 compressor that is about AUD $3500, but is for cars from 2008. This one probably needs the updated hose as well. You may want to check with your dealer again. The compressor (part number 95535890101) is USD $468 from www.Porscheoemparts.com I have used these guys many times to ship parts to Oz and highly recommend them. :thumbup: They use Fedex and are reliable. Even with shipping, your still way ahead.
  17. Was the failure as spectacular / catastrophic as your previous strut, or was this one a fizzer? Did the other strut also deflate or were you tilted?
  18. Reseat/Check left dash fuse 53 (5 amp) Reseat/Check right dash fuse 31 (15 amp) These supply power to the rear convenience module. Module is located in right rear cargo area.
  19. Code 1400 is "control position not adjustable - vehicle too low or too high" Code 1772 is "pressure transmitter signal lead" These faults point to the level control adjust unit or the solenoid block or associated wiring. The compressor is protected with a 40 amp fuse. It is located at position 13 in the main fuse box (over vehicle electrical system battery) as quoted from the service manual. This fuse feeds hot bus power to the compressor via a relay.
  20. Ok RFM. So what could be causing the tilted attitude on the OPs Cayenne?
  21. Really. I thought there was only 1 compressor.
  22. The higher performance turbo engine will run warmer especially when your on the boost. It is logical due to the extra cooling required for the turbo chargers. I have driven mine hard in the Australian summer and the needle does tend to creep higher on the gauge. Nothing to worry about as long as the needle stays away from the red.
  23. I buy from Svetila.com. They package the bulbs securely and deliver promptly. Highly recommended.
