GSpence2
Everything posted by GSpence2
  1. A scan with a Porsche dedicated tool like Durametric or PIWIS should be able to identify the culprit straight away A simple visual check may help as well, i.e., when you come out to the truck which end and side seems lower than the rest?
  2. You likely have a leak in one of the air springs or the valve body itself
  3. You need to have the scanned with an appropriate Porsche scan tool.
  4. Will do Joel. Thank you again for the suggestion. I suspect the O2 issues are old frayed harnesses. We shall see 👀
  5. Follow up Okay so AKG Intercoolers installed Getting the correct pressure pipes and hoses from Porsche was a pain in the arse because the parts manager couldn’t get it through his head I wanted parts that didn’t necessarily match my VIN # Took 3 tries and a week in delays After getting parts sorted and everything square I have noticed smoother boost and a big bump at 3200-4000RPM (stays solid at .7 bar) BUT... Now I’m chasing intermittent O2 issues Alternating too lean or too rich on booth banks I will pull some live data to compare duty cycles-on/off behavior on boost off boost to see if there’s any correlation
  6. I apologize for missing your question. We tried a few different ways. I have cold air intakes on with these large 6" come filters the easiest thing to try first was to remove a filter and intro smoke that way. Next we pulled off the bellows at the Y-pipe - I have an IPD plenum on - and put the wand in both sides traveling down to the MAFS and intercoolers.We pulled the IPD plenum off and got the wand through the throttle body to smoke the intake runners. Finally we pulled off the connections to the air injection pumps to see if there were any leaks at the CATS. A bit labor intensive but worth it.
  7. Jehle Custom Molded Subwoofer Enclosures for Porsche® Cars WWW.BILLJEHLE.COM Custom molded subwoofers for Porsche cars.
  8. Leaky valve block or air spring. You should get to a good independent with the proper scan tools to see where the fault is so it can be corrected
  9. Okay so for anyone following this thread problem solved! Smoked the engine and found big leaks between the MAFs and the intercoolers and again at the plenum before the throttle body. New seals replaced leaky pipes and hoses and voila! No more codes no boost leaks power drops and hesitation and smoother shifting too
  10. Nice I'll let you know how it goes. I've been wanting to do this since I had my engine rebuilt a few years ago. Bad scoring and piston slapped warranted a rebuild. parts on order. stay tuned...
  11. Nice write up. The T-clamps are they 3" , or 2" clamps ?
  12. No. I've replaced mind several times. Plug and play
  13. If you don't mind traveling a bit try Mike @ Formula Motorsports - Dedicated Porsche Service Center in NYC | Formula Motorsports WWW.FORMULAMOTORSPORTS.COM Exclusive to Porsche Restoration, Collision, and Repair in New York City.
  14. 2004 CTT Changed boost pipe seals because they were leaking Changed diverter valves because they were leaking New filters plugs & coils but I’m getting behavior like multiple misfires and Durametric codes P2236, 2238, 2225, 2227 Time for O2 sensors?
  15. As with nearly all Cayenne issues I think a good starting point would be checking and ensuring the battery/batteries and charging system are in good health and operating correctly I’ve been experiencing some weird drivability issues as well and the root cause is pointing to a possible/probable electrical system issue
  16. Need to get it to a Porsche dealer or specialist who can pull the DTCs My guess is a failing transfer case/transverse lock module and solenoid
  17. So I did some more data-logging today during a portion of my morning commute. Mostly low speed (below 25MPH) stop and go but a couple of places where I could really go fast (30-35MPH). If I am understanding and reading this data correctly my check engine light codes P2227 & P2225 are being caused by a vacuum and/or boost leak? Take a look and pay attention to time slots 12:59 & 16:57. Something weird happens both times when it feels like the timing is all of a sudden thrown off, and the truck hesitates, stumbles, loses power, and then snap crackle pops through the exhaust like a cheap rice rocket with a fart pipe. And each time this is with a steady easy throttle no mashing. Untitled.mp4
  18. I realized after the fact some of you may not have a .avi player so I reformatted the data-logging file as a .mp4 Untitled5.mp4
  19. So I pulled some live data today and am going through it now. One thing I'm not certain about that caught my attention is the correlation of ambient air pressure drop as intake air pressure rises; I thought this would actually be the inverse of what's being reported? Have a look. Untitled 5.avi
  20. So I tested the battery today and at rest no ignition I'm getting 12.6 volts. With the engine running I'm getting 13.85 volts. Battery is not even a year old yet. Okay no rodents, ECU check sums are checking out okay, BUT - I'm losing boost, and the timing is being retarded in a big way right when the turbos should start to spool hard about 26-2700 RPMs. Spool up to .3-.4 bar and then le poop! Full dump. Power loss, hesitation, stumble, no CEL - repeat. Hmm...curious... I'll try to capture some live data and post it. I'll try cleaning my MAFs too. I ran some Techron through a couple of weeks ago - didn't really need it but it was a gift so...
