toddmac12
    NJ
toddmac12's Achievements
  1. Both small half moons on either side face the valve cover.
  2. TDC for a given bank will have a larger "half-moon" on the crankcase side and smaller on the valve cover side.
  3. You will not be able to turn the rear wheels with the parking brake on. The drive shaft should rotate when you rotate your rear wheels.
  4. Did you try turning the rear wheels?
  5. LOL, you are right sorry for the mistake. The door lock mechanism was another repair I had to make. I was able to get my window regulator rebuilt for $180 from a service listed on eBay.
  6. I bought a used one on EBay in 2017 for $70. No problems so far.
  7. Check for vacuum leaks. Sent from my Pixel 2 XL using Tapatalk
  8. Where did you get them? Sent from my Pixel 2 XL using Tapatalk
  9. I bought the tool for $140 on Amazon. It's called Hub grappler puller. You will also have to get a hub puller set which sells around $100. It will more then pay for itself because the dealer or auto shop will charge you much more. Sent from my Pixel 2 XL using Tapatalk
  10. Check this out. Check the video out at 22:50 for the tool that is used to remove and install the bearings . Sent from my Pixel 2 XL using Tapatalk
  11. See photo where Reed switch is attached to vent valve. Sent from my Pixel 2 XL using Tapatalk
  12. See attachment photo Sent from my Pixel 2 XL using Tapatalk
