kenobiben
Everything posted by kenobiben
  1. Hi, to stop warning light just put a 16.7 tvs diode on the power supply cable of the xenon ballast. I did the same mod and solve warning light problem and spoiler stop working with this. RS code 815-2575. Bye
  2. Hi, yes definitely is one hydraulic lifter, I have the same noise when not drive my c4s for more than 1 month, but after few minutes the noise go away, hi think is when the oil become at good temperature.
  3. Hi, if you want to install footwell light, just take the +12v - gnd near the fuse box (see photo), there is 2 group of cable, a big one and a smaller who go to the door, take it in the smaller. +12v Red/black gnd Brown/yellow This is the supply of panel door light and they dim as the roof light. Just made a solder on the wire after cut off a little piece of insolation by knife. After it put isolation tape on it. That's all
  4. HI, in my 2003 996 LHD the sound of phone comes from passenger side(right seat) like you. I think it's normal because the microphone on the left of cluster is very near to left speaker, so if sound comes from left side you can have echo or larsen effect.
  5. Hi, I had the same problem especially when perform an automatic full scan of module and solved after installation of V27. If need more information please PM me Bye PS: Sorry Richard :blush:
  6. Final drive oil change Tools needed: allen 8mm for filling bolt allen 14mm for flushing bolt Torque wrench refill tool (see video) 1.2lt of 75w90 for rear final drive 1.5lt for front final drive Torque: 25nm filling bolt 28nm for flushing bolt Sorry for poor english ;-) Author kenobiben Category Carrera (996) - Maintenance Submitted 08/25/2014 10:15 AM
  7. Tools needed: allen 8mm for filling bolt allen 14mm for flushing bolt Torque wrench refill tool (see video) 1.2lt of 75w90 for rear final drive 1.5lt for front final drive Torque: 25nm filling bolt 28nm for flushing bolt Sorry for poor english ;-)
  8. Hi Rob just doing the Tiptronic oil ATF change and I confirm Fuchs ATF 3353 is red color. The used who comes out from tiptronic is brown after 90000km. Hope this help you Bye
  9. Oil pressure change Video tutorial https://youtu.be/KTEm9c5ANEc Do it when oil pressure still high 5 bar at 1500 rpm or 3 bar at idle or unstable Bye Author kenobiben Category Carrera (996) - Common Fixes and Repairs Submitted 05/27/2014 01:57 AM Updated 03/17/2017 05:07 AM
  10. Video tutorial https://youtu.be/KTEm9c5ANEc Do it when oil pressure still high 5 bar at 1500 rpm or 3 bar at idle or unstable Bye
  11. HI all, there's a youtube DIY for this http://youtu.be/KTEm9c5ANEc Bye
  12. I did it, take +12v from fuse box and you can go to the trunk passtrough a hole on the top of the fuse box. You had to remove the bumper for easy route of cable and glue the drl with neoprene. 2h of work but easy.
  13. Hi all, I have a 996 c4s MY2003 with PCM2. I want to change the battery. Need any radio code after change it or is it coded with instrument cluster or dme? Thanks for help Bye
