jl-c
Everything posted by jl-c
  1. The MOST loop must be completed either by the units the car expects or as you say loops. The errors are the clue.
  2. for future reference Gumipfledge on your seals and run a credit card between glass and seal before opening car. If the window is dropping and raising correctly when opening and closing the door, then the regulator and motor must be OK as long as it is the same amount as previously? Sounds to me as if the switch has failed, not unusual but cannot explain the thumps unless the cables were a bit loose and the slack was being taken up by the ratchet.
  3. there should be 2 holes in it to put a tool through and pull it out.
  4. E-bay Porsche trim clips, I just bought an assorted box of them. Cheap enough, remember Porsche don't make them, they probably buy them from E-bay too ?
  5. Technical data Transmission type: G97/01 Equipment: 6-gear Installed in: Carrera (997) and Carrera S (997) Model Year: 2005 Transmission ratios 1st gear: 3.91 2nd gear: 2.32 3rd gear: 1.61 4th gear: 1.28 5th gear: 1.08 6th gear: 0.88 Reverse gear: 3.59 Final drive ratio: 3.44 Filling capacities Manual transmission Filling capacity for dry transmission with differential Filling capacity 2.9 litre Manual transmission Change quantity for changing transmission oil Filling capacity 2.6 litre
  6. Mine did pretty much the same, drove it into the garage, all ok, come to drive it again, one side low! Seems they have removed what little lead content there was from them (so I was informed) and they just snap! Apparently quite a well known issue in the independents world. BMW springs do the same, had a couple fail on them.
  7. The Durametric is a great tool, but also dangerous! You have to think before pushing the button "what will this actually do?" Well done for finding it though!
  8. OK thanks, just me I guess? I’ll find something else to worry about! Still think its crazy that it should be so finicky though, whats wrong with a proper dipstick? ??
  9. This is an odd question I know, bare with me it makes sense. What part of our 911 ‘s is level? At home my drive way looks level to me, at work the car park looks level to me, the oil level disagrees! Check the oil at home, it is one bar low, check at work it’s full. I put a spirit level on the door sill cover it reads differently from the outermost surface of the door aperture, I decided as this has the be part of the shell and nothing is stuck to it (as the sill cover is) then it must be the most level part of the car. Level test at home, rear down a little, level test at work seems to be level, so check oil at work? Agree or disagree?
  10. Mine when I had it had Bridgestone RE05A's on. Loved them and grip was great wet and dry, when they died I thought everyone says how good the Michelins are so I went for a set of Pilot Sports 2, they are horrible. Not progressive at all, they snap out at the limits, and they are so noisy. The Bridgestones telegraph what they are doing, the Michelins don't. Running 2005 Carrera 2S with standard 19" Classic wheels. Next time Brigestone definately. My opinion, yours may differ!
  11. Thank you. Good advice as usual. Now I know what I am letting myself in for!
  12. Help please. Front Road spring broken on 2005 PASM 911S Coupe. Unsure from manual but do I have to remove the strut from the wheel carrier? Or, will it fold down on the lower ball joints/arms once the top mount is released sufficient to get the spring off? I also assume replace in pairs? Many thanks!
  13. OK, but I ask as if you update files in the wrong order and have an early amp then you are in for a world of pain! However if you say that is not the case, then it implies a break in the MOST loop?
  14. I also prefer the left design and am interested too, obviously depending on price.
  15. Lets face it, anyone can put any tyres they like on their car, the questionable thing is, is it safe? Now, I run a full set of Michelin Pilot Sports N2's on my C2S and find them inferior in grip to the Bridgestone Potenzas that were on it. It's all personal choice. As to safety, Porsche (with due deference to you yanks love of litigation) recommend (note the word recommend) certain tyres that they have tested and certified as suitable for the 911. Whether you take on that recommendation or not is up to you, but don't go saying " those 911's are crap, it threw me off the road" if you fit Linglong specials!
  16. Well, just as a closure to my original question. I stripped the system down and found one ram (microswitch one) leaking from the swage at the bottom and the other ram had the internal spring in 3 pieces. cut the top hat section off the two rams and had a pair of tops turned down for me and had thread cut into the original ram so I can screw the top on as required. I soldered up the swage joints and replaced the O rings on both rams and bought a pair of new springs. Rebuilt rams replacing crush washers etc. Suspended twin cylinder above the level of the rams which were back into the rear lid and removed the complete plunger assembly from both "syringe bodies". Filled both bodies up to the top with CHFs 202 mixed with 10% Lucas stop leak .Crack off the unions on top of each ram (rams obviously retracted by the spring action) and let the fluid bleed out. Lock the unions up again, top up the two cylinders, insert plungers and reassemble whole pump assembly using thread lock as required. Apply power and all fine. Reassemble lid and refit to car. Fully working again and if required I can easily replace O rings in the future. Very satisfying repair! Total cost under £200, just a touch cheaper than Porsche!
  17. Dansk sports on mine, sounds awesome! Tried the full sports Dansk first but was too loud (sounded as if there was no silencing at all!) but settled on their intermediate ones.
  18. Now firstly, I haven't done this with the Porsche but have with another car. The dealer ordered me an ignition switch to my key number and as such worked no issue. I would guess Porsche could do the same?
  19. Appears to be the seal between items 4 and 25?
  20. Exhaust support brackets positively pristine compared to mine! Due for replacement soon before they drop off! Good old UK salted roads.
  21. Talk to Porschelibrarian for your manual.
  22. This is what it should look like, as you say the cable clip is supposed to be part of the sensor retainer bracket.
  23. I was going to guess brake pad sensor or ABS sensor but tyre pressure may well be the answer! It says BERU on it I think?
