White987S
Everything posted by White987S
  1. You really don't need climate control in a convertible! Much better things to spend $550 on.
  2. Here is a good link: http://www.mobiloil.com/USA-English/MotorO...ls/Mobil_1.aspx They are not the same.
  3. Already? How many miles do you have, Soetekouw?
  4. Try: www.paragon-products.com www.wheelenhancement.com
  5. Have you checked-out RUF?? www.rufautocentre.com/parts/index.asp
  6. You can see some good examples on Eric's web site at www.bumperplugs.com.
  7. Would I be able to add the PSE from the 2007 Boxster to my 2006 987S?? Will this be made available through Tequipment? Thanks.
  8. Tweety, why take the oil out? Just keep adding a 1/4 quart at-a-time (every few minutes, to give time for the oil to register) until the dip-stick reads at the top of the full range. Then, monitor from there.
  9. Tweety, the most accurate oil level read will be first thing in the morning, prior to driving.
  10. Paul, you hear a lot of good things about Red Line and Royal Purple.
  11. The typical labor time, they charge for, is about 8.5 hours.
  12. Sorry. Not uncommon. Repair for RMS should be closer to $1,000 though.
  13. Bag Man, just a thought, you should buy the parts from Suncoast Porsche, and work a deal with the dealership you are considering to install the parts at "cost" for labor or make part of the final deal.
  14. Hey Bag Man, this link should help you. Good luck: http://e-partssales.com/Merchant2/merchant...ory_Code=996int
  15. The recommendation is under 4,200 RPM for 2,000 miles, not 5,000.
  16. IMO< the best thing you can do is make sure you are not running 0W40. Switch to another approved weight such as 5W40. WHY?
  17. Hey Tone01, just curious, what fluid will you use? OEM, Red Line, Royal Purple?? Thanks.
  18. Jimher, also have them check for TSB# 1726- for control piston in oil pump.
  19. $175 is a fair market price. I pay about $110 here is Chicago. I have seen prices as high as $250. I have paid about $70 when I brought my own oil. This is your first oil change on a 2001? I hope someone did it prior to you!
  20. In the Warranty Book (page #10 and 11 for the 2006 987) it states: Your Responsibility for Normal Vehicle Use To be driven on reasonable road surfaces within legal speed limits. Porsche guidelines specify reasonable mileage to be at least 15 miles/24 km per day or 6,000 miles/9,600 km per rolling 12 months. If you drive less than the above mentioned limits, or in the event of prolonged storage, contact your local authorized Porsche dealer for instructions. NOTE: A battery maintainer is available at your local authorized Porsche dealer. It must be used to maintain your vehicles's battery state of charge if your vehicle will not be used for several days.
