Please forgive a dumb question but I need to put my mind at ease.
C2S 2007 build Carrera Sport wheels with coloured centre crest.
I have a slow, front left-side, puncture which I will be getting fixed later this week. While searching on another forum for tyre depots that can be relied on not to damage rims I came across a comment that implied that removal of the wheel centre caps was the most difficult part of the task.
I will most likely buy my tyre on-line, remove the wheel and cap myself and take to a local depot to have it fitted.
Is there a recommended procedure for removing the wheel centre cap that will minimise the risk of damage?
Allan
Can't believe my luck I just happen to have one of those bits lying around in the garage - thanks. :thumbup:
i don't know about that drill bit method! ;)
you can make your own removal tool with a metal coat hanger. cut the coat hanger at one of the corners so that you have a metal 'V'. bend the ends of the V slightly inward towards each other. insert the ends into the two holes in the wheel cap, squeeze, and pull. ta-da!
you could also take the wheel off and pop them off from the inside.
Chris, thanks for your response. The wheel will be off the car so it looks as though this ought to be a very simple task. It was just that I read of someone having difficulty removing the cap, even with the wheel off, that made me think this might not be so straightforward. I've only had the car a few months, it's my first Porsche, and not had any need to remove a wheel until now.
I'd take the wheels off and pop them out from the back (you'll have access to the hooks that keep it in position). I've managed to wreck a centre cap with the hook it from the front method.
