996 engine warning light (1999)
Just bought a 1999 cab 996 and after driving it home for 270 miles the engine warning light came on. The light stays on and I had the code read as P1125. I just bought the car yesterday and need to know if I should return it or if this code should be just reset? Being new to owning a Porsche any info on this would be appreciated.
Also the car only has 36000 miles.
Edited by spankey
P1125 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold
This means that mixture on cylinders 3-6 is too rich and the DME can not correct for it.
Potential causes are:
- Fuel pressure too high.
- Fuel injector leaking.
- EVAP canister purge valve open.
Since you just bought the car I would go back and make them fix it.
Thanks for the info Loren.
Would it cause any problems to drive the car today?
Is this expensive to repair?
A little background as we live in Florida we were coming back from picking up the car and I pulled into Automax to pick up some wax. The temp. was 93 degrees so my wife stayed in the car and I left it running. When we took off from the parking lot there was some traffic coming and I got on it coming onto the road. I never even hit 6000 RPM's but that is when the light came on.
Thanks again for your help.
Edited by spankey
As long as the CEL is not flashing it is okay to drive the car (as long as it runs ok).
They have to find the problem before any parts/labor estimates.
If you had a P1123 (cylinders 1-3) also then I would say a dirty MAF - but since it is only on one side they need to look at the DME readings to tell if the MAF is working right.
Thanks for the help.
My '99 996 threw both right and left side O2 ODBII errors, and it turned out to be a bad MAF. If I remember the various threads I chased when it happened, it can be:
  • The dirty MAF you already know about
  • An after-market air filter
  • This little rubber connector called something like "oil bellows" (but that threw lots of ODBII codes)
  • An outside chance of a vacuum leak
Good luck dealing with the folks you bought from...
Everyone thanks for your help.
Took the car to the local Porsche dealer and it was the MAF. $800.00 later and I am on the road. The good news is the guy I bought it from agreed to pay 1/2 the repair bill. I am ok with that as I bought the car as is.
Thanks again for the responses.
$800.00 for a MAF, that's a whole lot of money for a part that only takes 5 minutes to replace.
