  • 6 months later...
Any recommend place (internet site) where to purchase a Durametric for a 06 cayenne, I do not require a professional version.
My understanding is with the standard its up to 3 Vehicles (VINs) and no round interface which I do not need becuase it will be for my cayenne, correct?
Hey Loren, they dont seem to have it for about $247, as you stated earlier in this post. I should have been more clearer with my question. So was wonder if anyone knew any other site that sells them.
That post was from February 2007 - most companies have raised prices in the last two plus years.
It is now $287. This tool will save you hundreds in the long run.
I have to apologize again Loren I didnt see/pay attention to the post date, and could not agree more. The reason i ask was it kept coming up as $347. I went around a different avenue on theyre site and found the standard version finally, that is $287. I perfer to purchase from them...
Thanks again!
Last question, will this clear airbag lights on a cayenne, has anyone try'ed?
Edited by madburg
Thanks again!
:clapping:
If you combine post #5 and post #6 it works. Just did it 5 minutes ago. Try pushing the odo/trip reset button and then turn the ignition on. The display will say Service Reset. Press the Reset button on the windshield wiper stalk. Reset complete!!! Go back to Enjoying your Car! :drive:
I just did this too - successfully! Pushed and held the trip/odo reset, turned on the ignition, then pressed the reset button on the under-side of the wiper stalk. Then it instructed me to depress the brake lever... and no more service message!
  • 3 months later...
:clapping:
Please specify year and model of your Cayenne including any updates. Thanks.
Mine 05 CS and many others have tried the method and didn't work.
:clapping:
See post 23 above.
"The Service Reminder can be reset with the Durametric Software (about $247) or by any shop (or owner) with a PST2 or PIWIS.
The original method only seemed to work on a few of the early cars."
