I have noticed every now and then a strange chirpping with ticking noise coming from the engine @ idle; I know the lifters make some ticking sounds but there is a distinct chirp as well. The sound comes and goes and some days I never hear the chirp but just the normal lifter ticking. Anyone have any ideas what could be causing this.
Thank you
If it does not go away when warmed up then you should have your dealer check it out - while you are still under warranty.
I will Loren and thanks. The wierd part is it comes and goes from day to day. Edited by 500
This topic came up a while ago with a fellow with a 996. I had the same noise and was concerned. The culprit turned out to be a loose spark plug. I torqued mine down and the chirp sound vanished. The other fellow's mechanic told him that his crankshaft was out of balance and would require a new engine! Oh my!!! Make sure to do all your research.
There is a thread here with a sound bite that illustrates the chirping sound. I'll see if I can find it and post it.
Hope this helps
Phillipj
Hope this helps
Phillipj
Thanks so very much...this was very helpful! :)
If I can quickly check to see if the spark plugs are torqued properly it will save me a trip, also the noise is intermittent so there's only about a 50/50 chance it will be there when at the dealership. If the plugs are tight then I'll have to bring it in for sure.
Edited by 500
There are a lot of 997 with chirping serpentine belt rollers, only cars with man. gearboxes, they have plastic rollers. The ones with tiptronic have metal rollers without issues.
It's been my experience that dealers typically lack the incentive to find 'strange and/or intermittent' problems on warranty covered cars. What they usually do (if they can't locate or confirm the customer reported problem) is perform some other maintence action so they get reimbursed from PCNA.
Good ideal to check obvious things first (if you can) before bringing the car into the dealer.
Good to know, thanks. I wonder why plastic on 6 speed's and metal on tips?
Edited by 500
Very true.
In the beginning yes, you can do the following steps:
top up the steering fluid level to be sure
do a test drive til the noise is there
remove the air box and the belt
let the engine running without the belt for MAX. 1 MINUTE ( the engine can overheat )
if the noise is gone check by hand which roller or pulley is the cause
if the noise is still there go to the dealer
COUTION: the engine runs without air box/MAF sensor a engine check will occur, clear the code.
Thank you RFM.
If the noise is still there what might it be?
If the noise is still there go to the dealer, there are more possibilities for this sort of noises, release bearing etc.
Success.
Thanks.
A clutch kit was recently installed along with a new flywheel all under warranty as the car was suffereing from clutch chatter since new. I believe the chirpping noise was also there before the clutch work. I will take it to the dealer if the belt test is not successful. I have read here a loose spark plug could cause the problem so I will check that too. Can it also be a lifter?
Edited by 500
In general lifters dont chirping, it's rather ticking.
Yes I realize that ...
I was thinking perhaps one of the lifters may not be getting enough oil or malfunctioning in some way which may be causing the chirpping sound.
