Is there any downside to the common Boxster hack that turns on the headlights when you turn on the car? The hack uses simple fuse box jumpers
From what i understand, Canada has the daytime lights law, maybe you could just get the relay from a Canadian dealer.
Just installed jumpers between fuse 6 and 9. The headlights come with the key. I works fine - If I get tired of it, I'll change it back. Done.
Just curious, for those of you who have done this, do you find that you go through headlight bulbs at a tremendous rate after making this change? The GM cars don't seem to, but we used to have a Volvo 940 that went through headlight bulbs like water. I always attributed it to them being on all the time.
I have this hack on my MY 01 S.......it works fine.
Today a friend bought a MY 01 S with factory Litronics........same 6 & 9 fuses for the HID's?
Mine is hacked to run the foglights as DRL. I think it looks better...a car imported from elsewhere will not pass inspection into Canada without Daytime running lights.
Mine is hacked to run the foglights as DRL. I think it looks better............
That's what I would rather do (and move my CQ 5000K's to the foglight socket position as well, if they're H7's).
What year is yours? How did you hack the fogs for DRL's?
Edited by 986fan
Mine is a 1997...
You run a wire from the foglight fuse to pin 86 of the foglight relay.
When ignition switch is turned on foglights go on.
When highbeams are on, foglights go off.
I just imported a 1999 Boxster to Canada from the Us and needed a Daytime Running light mod to get the RIV approved. Canadian Tire wanteed almost $400 to do it. I did it myself for $10 in parts and my own know how. I'm going to remove it as I beleive it does shorten lamp life.
Mine is a 1997...
Thanks.....I'll try it.
Interesting - have a set of LED DRL's and was looking for a way of doing the very same thing. Is there an 'dummys guide' anywhere I can look at at :)
Interesting - have a set of LED DRL's............
......And that was my next question. LED's for fog lights locally available at an Autozone, for instance,
or on line? Where did you get yours? They should burn cool also, shouldn't they?
What type (number) are the '01 foglight bulbs (986 w/std headlamps)? Cars w/Litronic headlamps use the same?
Everywhere I look I find refrences for all of the lights on the vehicle except for the fog lights.
2001 PORSCHE Boxster (With halogen capsule headlamps)
Low beam headlamp
H7
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7EB EcoBright - Your Environmental Choice
H7XV XtraVision Halogen - The Brighter Light
H7CB Cool Blue Halogen - The Whiter Light
High beam headlamp
H7
Parking light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
7506
7506ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
7507
7507AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
7507LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
5007
5007LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
7506
High mount stop light
2821
License plate
6418
6418LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7506
Front sidemarker
2825
Rear sidemarker
5007
Map light
2825
Dome light
2825
Step/Courtesy light
2825
Trunk/Cargo area
6411
Under hood light
6411
Edited by 986fan
It is on mine :)
Interestingly, I did a search for the same bulb for a US car, it came up blank ?
Edited by Gary H
My DRL hack is to turn the fogs on manually. HIDS does not come on. I usually only use on two-lane roads. And I want to be able to turn lights off at times while the engine is on.
I want to be able to turn lights off at times while the engine is on...........
Best of both worlds - I bought a switch at Radio Shack (P/N 275-730). Hold the bracket up to the
bottom of the dash, as far forward as it will go and hard against the driver's side of the console.
Drill 2 very small pilot holes through the places provided on the bracket. Install and tighten the
2 supplied self-tapping screws. Snap the switch in the bracket.
This is very sturdy, very out-of-the-way and matches the other dash switchgear well. The switch
has a positive feel and is rated at 25 amps (way much!). there are large male spades on the back.
Run your DRL hack wire through the switch........You can then allow the DRL hack to function, or return to
regular mode "at the flip of a switch".
I had to get down pretty low to take these pictures. You don't even normally see the front of the switch (you
would have to be looking for it), let alone the back or the wiring. Still, it's easy to slide your hand down and hit
the button (rocker). Your feet or knees won't even get within 8" of it.
  • 9 months later...
I am considering trying the hack on a p-car with Litronics - does it work in the same way?
Works the same on Litronics. A note to everyone doing this though, is that this hack is only for the front lights - so remember to turn the lights on at night. :) Here in Norway, and most of Europe, the normal configuration is that both front and rear lights turn on when starting the engine (and even innstrument lights, etc. We're not used to operate a light switch at all.)
Atle
