Anyone have a writeup on removing the CDR23 on an 08 Cayenne? I want to get behind it to install the mObridge IPOD adapter.
There was an old writeup on another board, but the pics are now gone, so the text is useless.
1. Switch off ignition and remove ignition key.
2. Use a plastic spatula to carefully unclip the covering frame, starting from the bottom left and right.
3. Unscrew both fastening screws.
4. Pull out car radio together with oddments tray. Unscrewing fastening screws and removing the radio.
5. Press electrical plugs on radio and then pull off.
Will this work for a MY04 Cayenne as well?
Yes, it should.
  • 4 months later...
Hi, I hope someone can help with my Cayenne 2004. I disconnect the battery and now I have lost the radio CODE. Any help wold be appreciated.
CDR23 E1 EC: 116
Model#: BE 6627
Serial#: 45019692
CDR23 E1 EC: 116
Model#: BE 6627
Serial#: 45019692
Please read the FAQ - CDR-23 does not have security code.
