Just got back from the mechanic this afternoon regarding the top operation on a 2000 996 convertible.
The top moved 2/3 of the way from opening the lid, unlatching and almost finishing it's cycle - but coming short every time.
It turned out to be a "slightly" leaking hose, which I thought wouldn't be such a big deal.
He turns around and tell me it's not that simple and that the entire "operating piston" has to be replaced because it was designed not to come apart.
Just looking for a second opinion and hopefully a cheaper alternative than the $800.00 parts price I was given.
Fingers crossed....
Thanks.
Fingers crossed....
Thanks.
digigo:
Read the following threads, they may give you some insight as to what your top problem might be and possible solutions:
http://www.renntech.org/forums/index.php?showtopic=6967
http://www.renntech.org/forums/index.php?s...pic=5945&hl
Thanks Maurice,
I read those over the weekend and they gave me a little insight as to what and where the problem might be.
With the back panel removed (as shown in the photos for filling the reservoir), I actually saw the small leak - my problem is that the hose is not sold on it's own (as far as I can find) and the cylinder cost is around $700.00
I was just hoping for a magic solution or maybe a trick that someone has come across for not having to pay that sum for something as simple as a damaged hose.
That is a good thread though with the helpful photos....
Thanks.
digigo,
Had the same problem. Found a used cylinder for $250.00 from Okalhoma Foreign and replaced in about 2 hours. Doesn't matter which side you get as they are interchangable.
Spankey
Thanks for the lead!
My local guy said $800.00 for the piston, Jeff Clark at Sunset Imports can order it for $507.00 (quite a discount!)
But it feels kind of silly to spend that kind of money just for a hose - I've emailed Oklahoma and we'll see if they have one.....
Thanks Again.
