Hi All,
I'm changing the ATF and Filter in MY03 Boxster 2.7L Tiptronic.
after checking the ATF Porsche part# 000-043-204-63 or 999-917-547-00 which suppose to be Esso ATF LT 71141, not sure what the color of this ATF.
went down to the dealer in rocklin and got 4 Liters (I think I need more than that) price is $17.80 per liter porsche part # 000-043-207-00 and it is goldish color. Is this the right ATF?
under the DIY Menu - retail price search, I entered all the part numbers above and this is what I got
part # 000 043 204 63 , desc is SS 00004320490 msrp $434.37
Part # 999 917 547 00 , desc is SS 00004320700 msrp $263.54
and
part # 000 043 207 00 , desc is transmission oil (20 msrp $314.71
Are these part numbers suppose to be the same, if so, why all have different MSRPs.
Help Please!!!
The part numbers (and prices) likely are different because they have changed products and suppliers.
I agree with RFM - 4 liter is just barely enough.
A new Tiptronic takes 9 liters and the service manual says an ATF change takes 3.5 liters - but my experience has been closer to 7 liters.
Hello.
I'm not sure for MY03, but on my MY97, the transmission is a ZF 5HP19
that was also installed in other car like Audi A4 and VW passat.
It's an easy DIY, and you can use VW/Audi oil G052162A02 or
Pentosin ATF1 since it's cheaper an it's the same as the Porsche one.
link to ZF transmission
Link to a DIY of a 5HP19
Good luck
Hello.
Good luck
Hello.
Good luck
El Acura you are correct. I actually got 4 liters of the VW G052162A01, difference between A01 vs A02 is the amount of ATF in container.
but 1 day later ( after reading so many threads ) went and got it from Porsche Dealer. VW is about a dollar more than Porsche.
Thanks for the reply
El Acura
It is part # 000 043 207 00 , it is not solid in one liter container, at Rocklin Porsche if you bring your own container they'll give you what you need ( no halfs ex 3.5, 4.5...etc.) and it is $17.80 per liter.
