Is it possible to take a 99' C2 DME 5.2.2 and replace it with a DME 7.2?
Keeping all other systems the same (cluster, non-EGAS, etc.)
Reason is to possible change mapping on the 7.2 via Softronic flash. Softronic only starts programing at 7.2
Being able to tune the DME with software like Softronic. Which has shown some decent gains. Probably wouldn't be worth it other then I won a chance to flash my DME, but doesn't work on 5.2 DMEs. So if I switched to 7.2 I could use it. Just not sure if I would have to switch to EGAS. Or is the rest of harness is wrong.
