Cylinder 3 missfiring .
Check the spark plug, coil pack and wiring on that cylinder.
Swap parts to a know good cylinder and see which part follows the change.
Thanks Loren,
I changed my spark plugs a few weeks ago, so they are good. But maybe I damaged the coils at
the same time.
I also changed my water pump and the reservoir the other day, so I thought maybe some coolant got into the coils since
the cylinders that are missfiring are under the coolant reservoir.
How do I unconnect the coils to swap them out?
Kristian
PS.now I have codes P0300 P0302 P0303
Edited by kristian
I replaced the coil packs. The car works great now, much smoother than before.
i also cleaned the maf with electrical cleaner, clean the carburator and I put some
techron fuel injection cleaner in the tank.
Thanks again guys.
Kristian
I just ordered six coil packs from Sunset Imports at $42 each. It was the best deal out there.
I will let you knot the outcome when I install them.
Kristian
