Black & Decker DC port Starter/booster?
My battery is completely dead and I'm trying to get my trunk latch to function. The engine is dead so i'm not trying to start the car. I just want to get the trunk latch to work.
I got the Black and Decker DC port starter/booster. I can't seem to get it to work. Do you have to turn the key to the accessory position?
No matter what I try the unit beeps telling me something is not connected properly (beeps repeatedly) I did get some temporary power to the interior when I hit the "Boost" switch to the interior (dome light, door chime) but the trunk and engine cover levers were still frozen.
Then all power goes off again. Am I doing something wrong? Any help would be greatly appreciated.
Phillipj
RFM,
The problem is I can't open the trunk to get to the battery. I guess I will just tow the car as is. I was hoping to get the trunk open so that the mechanic could get to the battery easier.
I won't try again with the booster
Can you give me an idea where the emergency cable is for the trunk? The right side wheel well? Where approximately?
Phillip
Emergency unlocking of the luggage
compartment lid and engine
compartment lid
If the battery is discharged, the lids can be
opened onlywiththe aid of a donor battery.
Unlocking lids
1. Use the key to unlock the vehicle at the door
lock.
Leave the key in the door lock.
2. Remove plastic cover over the fuse box.
3. Pull out positive terminal A in the fuse box.
4. Use a jumpercable to connect the positive
terminal of the donor battery with positive
Note
If the vehicle was locked, the alarm horn will
sound when the negative cable is connected.
5. Use the second jumper cable to connect the
negative terminal of the donor battery with
latch striker B.
6. Switch the alarm system off by locking and
unlocking at the door lock.
7. Unlock the engine compartment lid or luggage
compartment lid with the switch.
8. Disconnect the negative cable first, then the
positive cable.
9. Push positive terminal A into the fuse box
and push on the plastic fuse box cover.
Note
Theenginecannotbe started with this method.
Please observe the chapter "Emergency Starting
with Jumper Cables" for this purpose
OOPS. Sorry. I've owned a 02 and a 00. I get them confused.
If the rear lid is open you can jump it there.
I know there is an emergency cable for both front and rear, but I've never had to use them.
I THINK the front is behind the passenger side wheel well.
Phillip,
There are different possibilities:
1/ buy a cigarette lighter adaptor, two pieces of electric wire ( 1.5-2.00mm diameter and 1m long ) solder the wires, one on the + and one on the - of the adaptor, two crocodile clips ( smaller than the classic jumper cable ones, but big enough to grab the battery + and - ) and solder them on the opposite side of the wires, take a spare battery in place in front of the passenger seat, install the self made tool, close and open the doors with the REMOTE, pull the trunk handle.
2/ use a battery maintainer as Loren suggest and do the same with the REMOTE as mentioned above.
3/ remove the trim with the handles and disconnect the electric lock motor, pull the handle.
Hope its helps.
