Secondary Air Pump
Ok, I have a secondary air injection problem. (don't have the codes on me right now)
i've read a few articles here on the pump et al.
this last weekend i opened up the engine compartment and started the car (cold) to check for noise coming from pump.
no noise. no movement.
any ideas on where to start? Fuse? Ground? Relay? Sensor? etc...
Potential causes:
Secondary air injection pump does not work.
- Wiring harness or fuse
- Relay
- DME control module
Air supply lines restricted.
Electric change-over valve does not work.
Air change-over valve does not work.
- Air supply lines
- Secondary air injection pump
- Electric change-over valve
- Air change-over valve
Look for these
Vacuum system leaks
Put the car through emissions yesterday, passed!
driving around after the party last night... start the car cold, pump cycles on and off, 15 seconds later, i get this code
P0410 Secondary Air Injection System - Signal Implausible (Cylinders 1 - 3)
the fuse is ok, pump turns on ok.
my97 with a my99 engine.
