High Miles 149000 on a 996
Hello everyone on my way home last night my daily toy hit 149000 miles.
:renntech: :renntech: :D
5/10/06 Oil Change 102500 Miles
7/28/06 Altonator $300 and $60 Belt Tensioner
9/26/06 Paid off Loan
10/8/06 Oil Change 110500 Miles 9.3q $70
11/4/06 Back tires 265/35/18 Kumho ECSTA $300
2/1/07 Front Brakes 115000 Miles $350
2/22/07 Front tires Kumho ECSTA 116500 Miles
3/17/07 Oil Change 117500 Miles 9.3q $70
6/7/07 K & N Fileter 120,000 $450
10/1/07 Oil Change 125500 Miles 9.0q $70
10/31/07 Nexen N3000 Tires for rear 127000 Miles $300
11/11/07 Water Pump and Thermostat 127500 Miles $417
12/9/07 Window Regulator Passenger 128900 Miles $170.91 Sunset Imports
1/6/08 Spark Plugs and Row Mo30 and new plastic hard wear in front by tires 130,000 Miles
1/9/08 Windshield Repair 800-944-4577 // 714-992-9112 $50
1/30/08 Another Windshield Repair 800-944-4577 // 714-992-9112 $50
2/4/08 132000 Front Brakes (just pads)
3/16/08 134000 Oil Changes 15 W 50 9q
4/5/08 134500 new Battery and
4/5/08 Rear Brake pads only
5/1/08 134700 AOS - air oil separator $600
5/8/08 13500 Transmission Service $313
7/7/08 138479 Mileage check 7/23/08 139391
8/1/08 140000 Mileage check
8/23/08 141275 Miles Oil Changes 15 W 50 9q
11/7/08 145000 Mileage Check
11/26/08 146000 Mileage Check
1/17/09 148456 Oil Change 15 W 50 9.3q
I got 12000 out of my rear nexens, they are not good at the track as they age. The fronts are going fine. Will us Pzero rossa's for the track, much more traction. Presently approaching 93000 with only clutch, RMS, IMS and brakes. Can't wait for the snow to go away.
Jim Greer
Tip or Stick?
I was looking at your maintenance.... AOS $600 and Tranny Service $313
those are at an indy or dealer....
(I did DIY for both of those)
you change your own oil ? (also 9q and 9.3q... do you not change filter every time?)
congrats on the miles... I am at 108k and happy today knowing you are still running strong ! ! !
Edited by ivangene
Tip or Stick?
hello,
it is Tip, and yes an independent shop did my aos and tranny. i am sure i could have done the tranny but aos ?? isn't the engine have to be lowered for aos??
i had to take my car 2 places then a dealer to find out it was aos, it wasnt smoking just making squeaky noise.
one place, while they had 2 959 's setting under the cover and 10 or so 996's there for service they thought it was the transmission.
another place same type of cars being service but thought it is the engine.
took it to the dealer paid the $300 or so to diagnose then to a independent shop.
how hard was it to do replace the aos ??
i do every oil change and do change the oil filter every time.
my 996 hit 150000 today
  • 3 months later...
