Speaker wire colors
Looked it up in the tech manual. Yellow/brown is negative, Yellow is positive. This is for one speaker, but basically all the color/browns are negative and the solid color wires are positive. The color mix is based on which speaker it is. This should help keep the speaker in phase.
  • 5 years later...
Does someone know all the colors of the speakers?, I know brown stripe is always negative, yellow is front left, struggling with the others.
Speaker wire colors will vary to some degree depending on the car model year - as well as model of radio (or PCM) and any amp/speaker option sets.
So please state the above and someone will try to help you...
Usually
Left Front (Yellow+) and (Yellow/Brown -)
Right Front (Red +) and (Red/Brown-)
Left Door (Green+) and (Green/Brown-)
Right Door (Violet+) and (Brown/Violet-)
Left Rear (White+) and (White/.Brown-)
Right Rear (Blue+) and (Blue/Brown-)
Edited by kbrandsma
