I have a '98 Boxster. Almost every morning lately it has been spitting out white smoke from the exhaust? Sound familiar to anyone? help...
I think that several people have talked about this on the site. I had a 99 boxster and got a puff of white smoke infrequently (i.e. 1-2x per month). I think that this is also discussed on Pete's Boxster board (another good resource for Boxsters)
As long as it only lasts for a minute it is supposed to be normal with Boxer engines. Something about the oil not draining away fully due to the horizontal cylinders - it gets burned off on start up causing te smaoke.
Mine does this - if I stop and start the car a few times without driving much I get a few puffs of smoke. Took it to an OPC who said its normal.
Yes, I heard that as well but it just didn't sound right. Quite a strange flaw... The part I was concerned with is that it seems to happen more often now and my engine light came on. I hate that **** light! Anyone in the San Mateo or bay area have a reader to read the code?? I just dread going to the "stealer". :help:
Nader,
My car is also having the smoke at start up. Check for my post since I recieved great tip from (the guru).
I do have the reader (not from porsche) and it works on my 97.
I can plug into your car and see that the error code. I work in San Mateo so we can meet during the weekday to have this done.
-Nat
Scouser,
I know what you meant :-). But zee here meant ...zzzzzzz or zoom ..zoom.
I also like the 350Z myself. I did not realized (it sounds like the ..other word) until the username was created.
Hope, this can clear out your curiosity.
Cheers,
-Nat
Just as long as you don't put a swasticker in your avatar ;)
Still think you should consider changing it though "natzoom" sounds better IMHO. Anyway, thanks for explaining.
