PCCB Pad Replacement - Parts needed?
sws1
Plan on replacing my PCCB pads and want to make sure I'm ordering all the correct parts.
Front:
4 caliper bolts
Set of front pads
Set of sensors (DO I NEED THESE?)
Rear:
4 caliper bolts
Set of rear pads
Set of sensors
Do I need to replace the vibration dampers? If so, what parts do I need? Front / back?
Do I need any sort of brake "gel"?
Are there any other parts that are needed? (pins / springs etc.)
You will need some brake pad goo. If you
buy stock pads you will be OK but if you don't,
Get some zip ties to tie the sensors up and away
from the brakes. The hardest part about doing the brakes on
these cars is removing the tire. Everything else is a piece
of cake.
Paul
of cake.
Paul
Not sure I understand.
I DO need "goo"? Where do I put it?
Is your comment about stock pads (which I AM going to buy) related to the sensors? Don't I need new sensors?
What about the vibration dampers? Can I just leave the existing ones in?
Edited by sws1
If you buy the vibration dampers you do not need any "goo" - that is what they do.
You do not need sensors unless your brake wear light came on. If the light comes on it is because the sensor wire was broken - in that case you need sensors.
