Click here to Donate
Sign in to follow this
c337cc
PST2 Cable
Does anyone know where I can get a new cable for my PST2 ?? I need the cable with the 16 pin OBD2 connector on one end & the 20 pin serial connector on the other end.
Howard :renntech:
Share this post
Link to post
I think it is:
00072195885 TESTER WIRING CABLE -- US MSRP $259.30
Thanks for the part # Loren. I will give that a try but I was told they are nla from Porsche
Share this post
Link to post
You can build one with the following:
1) Untermianted J1962M OBDII cable, available from obd2cables.com
2) Honda connector PCSE20LB - $4.98 each, PCSE20FS - $3.54 each. Available from chriselectronics.com
However, I failed twice at deciphering how to wire everything up, and my soldering skills are not good. Tholyoak is an expert at this stuff and can give you more detail.
Share this post
Link to post
Do you happen to have the pinnouts for the 20 pin side?
Share this post
Link to post
