Resetting dash clock?
I'm sure you've pushed in and held the adjustment button and done all sorts of twisting and turning it. The only other thing I can possibly think of is disconnecting the battery and seeing it it sort of "reboots" the clock....but make sure you have your radio code handy. If not....Loren can usually find the code. If you opt to try the reboot, you can get radio info by pushing certain buttons in a particular sequence and it displays radio technical info....check your manual.
Thanks Loren/Chuck. I checked the stalk again and it seems to work fine. I noticed this started happening after I started to use the trickle charger. I'll try to reset the battery and see what happens
Edwin
