What's the most likely cause of a slight oil leak on the pass side
Hi. under the engine, on the passenger side, I notice a slight film of oil.
Not likely a spark plug tube on a 3.6 liter - different design.
You should clean the bottom of the engine as best you can - then take the car for a short drive and see if you can see the source of the oil.
