Help with Battery
Hey guys
I purchased an 02 996TT last January from a P-dealer, the car is CPOd. The battery on the car was very old (2004) and it had a blue/green foam that accumulated on one of the terminals. I replaced the battery with a new on 3 weeks ago and cleaned the terminal. Yesterday I opened the battery cover and found the bluish/greenish stuff all over the same terminal again. my questions are:
1) are those symptoms of a faulty alternator/electrical system (overcharging the battery)??
2) will my CPO cover this?
thanks a lot for your help
Greg
1.check for any crack(post area) + vent line,,,,terminal corrosion is usually caused by hydrogen gas gasing(venting out)
2.check all the main wiring
3.dis-simillar metal can also be responsible for this, take a look at your terminal connection (battery post being lead againt coated copper/stamped steele?)
Be sure that the battery vent line is connected.
Very good point!
I installed the new battery myself and I made sure the vent was conected, I am not expecting them to pay for the new battery I got 3 weeks ago, I was asking if they would replace the alternator... I have a Fluke meter, should I let the engine idle and read the voltage at the battery terminals? what voltage should I read?
Thanks..
Edited by MechanicalEng
it reads normal, around 14v I believe, but I dont trust the gauge... I just droped the car at the dealer yesterday, they will look at the battery and at a check engine light that came on last weekend (secondary air pump) I will let you know the results...
thanks for your help
Voltage should be between between 13.80 Volts and 14.50 Volts at idle.
Hey Loren,
I have an '03 996 C2. After driving, my voltage read 13.43 VDC at the
battery terminals. Would it be the battery, voltage regulator, or alternator?
The battery is a couple months shy of 2 years old.
I am going to get my battery load tested today or this week. Is it possible to
have a battery on a battery maintainer (Porsche) too much?
TIA
Regards,
Paul
:renntech:
Edited by PDL996
That voltage is just a little low. AC and all fans should be off during the measurement.
Any large current draws?
The battery test is essential as a bad battery simply will not take a charge as it should.
If it is a "maintainer" then it should be shutting off when the battery is at capacity - a "charger" does not do that and can damage a battery by over charging.
I performed a test. The battery maintainer automatically shut off. Drove the car for an
hour and made 2 stops. Returned home. Made sure that everything was off and measured
the voltage at the battery terminals. It measured 13.43 VDC at idle. I am going to get the
battery load tested next weekend.
What would be considered a normal current draw? I'll have to measure the current and isolate
the circuit that has a large draw, if one is found.
TIA
Regards,
Paul
:renntech:
Hey Loren,
Are you having problems with slow cranking speeds or starting issues? A few 10th/volt low is nothing to be worry about unless you have other issues.
TIA
Regards,
Paul
:renntech:
Hey Loren,
I seem to be having some slow cranking speeds and the start does not sound right all of the time.
TIA
Regards,
Paul
:renntech:
