Secondary Air Injection
Gilbert,
I got your email and responded. These are the same codes I had and I replaced the MAF sensor. Unfortunately, my light just came back on. Let everyone know what the dealer estimated and told you; I'm sure you'll get some useful feedback.
Anyone,
If the MAF is not the issue, what else would cause these codes?
Nader
Could be anything in the picture above.
According to the OBD II Manual:
Secondary air injection Pump fuse.
Secondary air injection pump does not work.
Air supply lines restricted.
Electric change-over valve does not work.
Air change-over valve does not work.
Vacuum system leaks.
  • 4 weeks later...
