I'm a noob with my new-to-me 997. I have a vast collection of tools however no torx sockets.
Does anyone know if standard USA torx sockets will fit the Porsche or is there a different
type of Torx I need to get? Thanks.
There are some Torx head cap screws in the engine bay, the idler pully has one
and some other assemblies have a mix of Allen type and Torx.
Sorry forgot to mention it's a 2005 C2 Carrera.
I believe you may also need a female torx socket for the adjustment of the window resting height on the window regulator assembly.
You will need a small set of torx bits, torx female sockets, and a few triple square bits......When I say a small set several companies sell a set of six popular sizes. In my case find I get away with three or four sizes in most instances. For the triple square, these are a 12 point bit used on an internal wrenching screw or bolt. So far I have seen them on seat bolts, engine torque links etc. I have used two, a 10mm and a 12mm. I have attached some examples from SK Tools...Hope this is of some help...
Bob
post-40826-1261360787.jpg post-40826-1261360800.jpg post-40826-1261360811.jpg
I have a 997.1 and I have needed the female Torx sockets for a variety of things: removing guard plate for coils/plugs, removing throttle body, etc. I got a set from Sears on-ine for $9.99, plus shipping.
do yourself a favor too...
for the male torx set, just go ahead and get the Safety Torx version (female hole in the center).
Undoubtedly you will come across a safety torx screw somewhere and no sense carrying around two sets of identical sizes
Actually, for convenience purposes, once you have a set of safety Torx bits, you'll end up leaving your std torx set on the bench or in the drawer permanently...
