Cam Cover Gasket Change?
There is no gasket - it uses the sealant Drei Bond silicone - Type 1209 and Loctite 5900.
Problem is to do it right -
- the cover (which is really the camshaft cover) needs to come off and be cleaned
- to remove the camshaft cover you need to hold the cams in place
A coupe folks here have made their own camshaft holding tools.
Porsche book time is 4 hours - per cam cover.
