Errors From The Exhaust
After I run hard the car I receive this errors :
-P0430
-P0420
Should I be worried about this ?
It seems that the tuner can't bypass the cats... how do you guys run?
Does anybody know if there is any difference between the european ecu and US one?
Is here someone from EU that runs w/o cats?
It seems that they cannot "bypass" the O2 sensors from the ecu...
Any help please!?
P0420 TWC conversion, bank 1 - above limit
P0430 TWC Conversion, Bank 2 - Above Limit
Possible fault cause:
- Oxygen sensor ahead of and after TWC exchanged
- Valve lift fault
- Aged oxygen sensor after TWC
- TWC faulty
If the CEL is flashing the car should not be run.
- Valve lift fault
- TWC faulty
Hi Loren, the errors are form the cats, I am running w/o cats and the who tuned my car seems that cannot bypass the cats :(
Do you have any O2 sensors? If not you are going to always get these faults.
yes i have them. today my tuner put another file in, hope that this time everything will be ok but a strange thing happen, after they install the file my fuel gauge was dead it was showing
that i don't have fuel!
this is the second time that it happens after they install a new file, first time the gauge went up and showing ok after i put gas.
anybody can explain why?
thanks!
