Rear Window Replacement--Ny Suburbs
Man, I'm the world's biggest promoter of DIY stuff, but this rear window is not something I would recommend touching unless you have really strong fingers, hours of time, and ton of patience! The rear window on the 3-Series was a bear, and that sucker simply zipped in! Sewing a window will be very difficult - the material is very thick and not easy to work with.
The alternative I recommend is the roof replacement with the glass rear window. You'll never have to replace your annoying plastic window ever again. Here's the link to the article I wrote about installing the top with the glass window: http://www.pelicanparts.com/techarticles/Boxster_Tech/70-BODY-Convertible_Glass_Window/70-BODY-Convertible_Glass_Window.htm
Hope this helps,
Wayne
Hope this helps,
Wayne
Right now I'm vacillating between having a new window installed for $600, or replacing the entire top for about $1600-1800. I don't have the desire to do it myself. The local shops warn me against buying a new top online, as they can't warranty anything but their installation. Any advice out there? I should mention that my top is in nice shape, but it's 10 years old...
You can get a GAHH aftermarket top with glass window online for around $600. There's a guy named Peter Serbanica on the 986forum.com that is a top installer, and can both order the top for you (so you would get full warranty) and install it in around 4 hrs while you wait. He charges about $400 for the install plus the cost of the top, and so total price would be around $1k, if you're willing to drive to NJ to have it done.
No affiliation, but I was considering going with him prior to finding an OEM 2003 top with complete frame that I threw on my car instead. I would advise against going with another plastic window because all it takes is one cold day when you put the top down when it can crack again.
The alternative I recommend is the roof replacement with the glass rear window. You'll never have to replace your annoying plastic window ever again. Here's the link to the article I wrote about installing the top with the glass window: http://www.pelicanpa...lass_Window.htm
Hope this helps,
Wayne
Wayne:
Since you don't want to DIY, if you can find someone to strip off your canvas top and then install it again after you get the window sewn in, I know a local guy on Long Island who does excellent work who will sew in the window for $100, including parts (vinyl) and labor. PM me if you want the details.
Hope this helps,
Wayne
Wayne:
I'm not Wayne, but I'm interested. Please provide contact info. Thanks!
Hope this helps,
Wayne
Wayne:
BassMD:
Sorry about that! Sent you a PM.
Thanks, B. Spoke with him today and that looks like the way I will go. He suggested I wait until late summer/early fall or so, and that's what I'm going to do.
