Hello guys
It is obvious that the standard set up on 996 C2 + C4 ( Zimmerman discs+Texstar pads ) could use an improvement.The Texstar pad feeling is plastic and noneffective and the rotors start to veil after some hard braking (the rear at least)
I know that an big kit upgrade might cure but it is kind of expensive those days
So i have tried over the time the brembo pads and yes that's an improvement but also i am curious about other pads as Pagid,Ebc(red or yellow stuff),Jurid etc
I m sure that some reputable members here have also step into this issue.
Guess it depends on what you are primarily using the car for. My car spends most of its time on the track and I've found Pagid Orange to be quite effective on an otherwise stock bakek setup. Keep the brake fluid fresh too, that can make a huge difference as it's hygroscopic, absorbing water over time. If memory serves me, Pagid blacks are similar to the Porsche Sport pads and are probably worth taking a look at. I would NOT opt for a big brake kit. Our stock brakes have huge amounts of stopping power, and it is unlikely you will run out of brakin capacity on the street (or frankly even the track). Good luck.
  • 3 months later...
everything it's lead to Pagid as far as i can see
i also understand that the Pagid Orange are the best suit for my needs?
what about the Pagid black?
who carry them at resonable prices anyway?
I think that the best kit to upgrade the brakes are:
PAGID RS 29 front and rear
Goodridge Braided Hoses
Castrol SRF Brake Fluid
997 GT3 Front Brake Ducts
997 GT3-2 Rear Forced Air Ducts
Hope I help.
Hello guys
Are you testing with or without ABS enabled...?
The better the braking the more, quicker, ABS will intervene.
The only valid comparison testing is with ABS turned off.
well...rs29..i think that's the "yellow" pagid right?as well as rs44 is the orange type
yellow or orange i will try them for sure
goodrige are allready there
on castrol..i don't know,i am a dedicated fan off motul fluids
so far the rbf600 factory line from them has no matching opponent.as well motul oil etc..
ABS turned off...sound good sometimes but somethimes not.
but thnak's for the hint i will try it just for fan
hope i can deactivate it via durametric ,if not via his fuse
but who carry pagid at reasonable prices?i see that paragon is a dealer for united states,maybe other members can advice
cheers
