External Temperature
I've noticed that my external temp display is reading about 20 degrees (F) above what the actual temp is outside - has anyone else had this issue? Is it just a case of replacing the sensor or is there something more sinister going on?
Bob
Bob
first things first, make sure the probe hasn't been dislocated from it's retaining clip in the grille in front of the radiator. If looking at the front of the vehicle, it'll be on the left side...
Bob
Without knowing where you are located, outside temp displays can vary wildly during ambient temperature extremes. Yesterday, the air temp here was 95F; driving around over super heated asphalt, I saw outside temps that ranged from 85F to 110F.............
