Tire question
Hi guys,
Merry Christmas! Next week I'm planning on putting 4 new Falken ZE 912 tires on my 2000. Anyone have any experience pro or con with these tires and also, the previous owner put 215s on the front, slightly oversize. Any thoughts on that vs the stock 205 width? I like to toss the car around every once in a while but for the most part my driving is law abiding. I could do an occasional autocross with it but I have another car that is first choice, and I don't go balls out with either one, just looking for some grins.
Jim
San Jose, CA
Personally I run 245 up front and 275 in the rear on 17s. Those are Hoosiers so it's a little bit different story. My regular street tires are 235/255 on 17s. I like the better grip up front and have run my Boxster that way since back when it was stock.
-Michael
I have a '99 Boxster and run Michelin Pilot Sport 2's (PS2's) in 225/45/17 on the front and stock 255/40/17 on the rear. The slightly lower profile (45) on the front (compared to the stock tire 50) is needed to keep the tire diameter as close to stock as possible to avoid problems with the ABS (you need to lower the profile as you increase the width to keep the diameter nearly constant). This setup is meant to help reduce some of the inherrent understeer built into the car and seems to be the most common Boxster tire setup.
If you go wider than stock on the front and rear (e.g. 225 front and 275 rear) then you'll get a little more total grip but the the same stock understeer.
Edited by thstone
