I have seen conflicting information regarding replacing the clutch on the 997. I have seen some posts where the engine and gearbox need to be lowered at the same time, others where you can just lower the gearbox. Before I get elbows deep, I want to make sure that I can reach all of the bolts for the 997. Has anyone seen a link for a DIY or how to? If not I will take pictures and post how to perform this, but before I start I want to make sure that it is not mission impossible? Thanks !
Car is a 997 carrera 3.8 manual transmission (obviously) LOL 34,000 miles
Its blue, not sure if that adds to the difficulty!
There sure looks like very little room to
work on the nuts on the top of the transmission.
Post some pictures.
Paul
Thats what has got me concerned. I dont have a lift (yet) but I can get the vehicle high enough in the air to perfrom the job. I also have all of the lowering lifts for the transmission. On the 996, it didnt appear that difficult, but I am not sure if the top bolts are accessible. I am going to dig into it tomorrow evening to see if I can get to them.
I need to get a lift......
@ PAULSPEED Tiptronic gearboxes, manufacture of M.B., can not be removed separately without occasional accidents. Manual gearboxes are no problem with the gearbox mount removed and a slight inclination downwards of the engine-gearbox combination, the top bolts are accessible than.
  • 11 months later...
Replacing the clutch in the 996 is basically the same as the 997, and there are plenty of write ups. In addition to being very similar to the procedure laid out on the 996 work shop manual. There is another very recent thread discussing the same topic.
  • 2 months later...
