I am looking for a good tool to test the fuel pressure at the connection besides the fuel filter. I know the Porsche adaptor number is 9559 and the gauge is P378A . Is there something similar, less expensive, but of a good quality that I can found. Remember there is a valve under the cap besides the fuel filter and the adaptor got a plunger that depress this valves when installed. Thanks a lot for the info. J.P.
I think the adaptor needed for the port has to be M12X1.5.
Edited by jpflip
Contact Actron, they have two testers for fuel that retail for around $40, and ask if they have the correct adaptor for this application. If they do, that will probably be your cheapest out as everyone else is way over $100 for what you need. And don't even think about buying tools from Porsche, they are just plain nuts on pricing.......
Thanks JFP good suggestion.
Thanks again JFP. I finally got a proper tool to test the fuel pressure. This is good to eliminate a bad fuel pump or a rupture U pipe in the tank located on the pump canister. The Actron fuel pressure gauge is good Fuel pressure gauge # CP7838 but all the adaptors in the kit are useless for a Porsche. You have to get at the same time for less than $4.00 the right angle adaptor # 01800-000-1299. Just connect the adaptor and the gauge to the port beside the fuel filter and if you got 43.5 to 58 psi it is a good news ;-) (repair manual page 544). Of course you have to activate the fuel pump relay with Durametric to check the fuel pressure without starting the car. Or remove relay #13 from relay carrier #1 above the fuse panel and jump terminal 30 and 87.
post-29683-0-99901100-1300483955_thumb.j
post-29683-0-57356700-1300483966_thumb.j
Edited by jpflip
jpflip:
The terminals that you have circled look like number 38 and 87 in the diagram.
Thanks for posting the tool and procedure.
It is the German way to make the difference between the number O and the letter O in electric diagrams, terminal 38 does not exist on such relay, according DIN standards.
RFM:
Thanks for the clarification!
jpflip:
A blow up picture of the wiring diagram will show you a little difference between 0 and 8. It is important especially when you are ordering relays....
post-29683-0-15020000-1300536832_thumb.j
post-29683-0-39215100-1300536988_thumb.j
Edited by jpflip
