Spark Plugs
Can anyone advise what are the correct Bosh plugs, per the factory manual for the 2003, 2.7 Boxster engine? I read many opinions about what different people like, but no one seems to specify what the factory specs call for.
Edited by drobinson117
  • 5 years later...
On 4/11/2011 at 10:01 AM, Loren said:
999.170.207.91 Spark Plug (14FGR 6KQU)
Loren, is this still the recommended plug for the 03-04 2.7? I ask because after I purchased my Boxster I had some much needed service work done and they installed NGK plugs. I'm going to change out the coils (slight misfire on 2 cylinders) and I'm thinking I should install the Beru plugs instead. Am I wrong to do this?
Mine is a September 2004 2.7 Tip (last month of production).
8 minutes ago, Loren said:
:welcomeani:
The correct spark pl99917020791ug for a 2003 Boxster (2.7 liter) is 14FGR 6KQU.
Is seems that Bosch FGR6KE (7413) is the equivalent of Beru FGR6KQU? It doesn't seem like Bosch has FGR6KQU available?
Can you confirm?
